Canon PowerShot SD450 Motherboard Replacement
  1. Canon PowerShot SD450 Motherboard Replacement, Casing: step 1, image 1 of 1
    • Remove the battery and SD Card from their slots. Leaving these in could cause the battery to ground and ruin the electronics.
    • Unscrew the six screws on the casing. Two are on the bottom as pictured; two more are on each side of the camera.
    Ask FixBot
  2. Canon PowerShot SD450 Motherboard Replacement: step 2, image 1 of 1
    • Pull the lanyard mount off of the camera using a spudger or your fingers.
    Ask FixBot
  3. Canon PowerShot SD450 Motherboard Replacement: step 3, image 1 of 2 Canon PowerShot SD450 Motherboard Replacement: step 3, image 2 of 2
    • Find the line that separates the casing into its two halves. Hold each half separately, and gently pull apart.
    • Note that there is a small metal clip holding the two halves together. It might help to press down on the back half (indicated) while pulling upward slightly on the front half.
    Ask FixBot
  4. Canon PowerShot SD450 Motherboard Replacement: step 4, image 1 of 1
    • Take hold of the inside of the camera, and gently pull away from the back casing.
    Ask FixBot
  5. Canon PowerShot SD450 Motherboard Replacement: step 5, image 1 of 1
    • Remove the square, clear, rubber protector from the front of the logic board. This is not necessary to remove, but can easily fall off and get lost during later steps.
    Ask FixBot
  6. Canon PowerShot SD450 Motherboard Replacement: step 6, image 1 of 1
    • When you reassemble the camera, make sure the switch on the casing matches the position of the switch on the camera internals.
    • The black viewfinder padding can easily fall off the casing. Make sure you don't lose it when moving around parts.
    Ask FixBot
  7. Canon PowerShot SD450 Motherboard Replacement, Motherboard: step 7, image 1 of 1
    • Remove the LCD cable by gently prying the hinge open with a spudger or your finger. The cable should easily slide out.
    Ask FixBot
  8. Canon PowerShot SD450 Motherboard Replacement: step 8, image 1 of 1
    • Lift up the metallic-colored clip with the spudger to remove the shutter panel.
    Ask FixBot
  9. Canon PowerShot SD450 Motherboard Replacement: step 9, image 1 of 1
    • Remove the shutter panel with the spudger, now that the clip is released.
    Ask FixBot
  10. Canon PowerShot SD450 Motherboard Replacement: step 10, image 1 of 1
    • Use the spudger or your finger to release the orange ribbon from the logic board.
    Ask FixBot
  11. Canon PowerShot SD450 Motherboard Replacement: step 11, image 1 of 1
    • Pull the ribbon out of the socket using the spudger or your finger.
    • Disconnect the two other ribbons from the logic board in the same fashion.
    Ask FixBot
  12. Canon PowerShot SD450 Motherboard Replacement: step 12, image 1 of 1
    • Lift up the large green flap by using the spudger to pry up top right yellow edge.
    Ask FixBot
  13. Canon PowerShot SD450 Motherboard Replacement: step 13, image 1 of 1
    • Pull the flap back with the spudger so that the logic board is exposed.
    Ask FixBot
  14. Canon PowerShot SD450 Motherboard Replacement: step 14, image 1 of 1
    • Use the screwdriver to remove the three screws on the logic board. Take note that the bottom right screw is shorter than the other two.
    Ask FixBot
  15. Canon PowerShot SD450 Motherboard Replacement: step 15, image 1 of 1
    • Use the spudger to carefully remove the logic board from behind.
    Ask FixBot
  16. Canon PowerShot SD450 Motherboard Replacement: step 16, image 1 of 1
    • Remove the detached logic board from the camera.
    Ask FixBot
Chris Wren
68 Reputation
1 Guide authored
Cal Poly, Team 25-85, Amido Spring 2010 Member of Cal Poly, Team 25-85, Amido Spring 2010
CPSU-AMIDO-S10S25G85
4 Members
5 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 10
Past 30 Days: 41
All Time: 2,600
