Canon PowerShot SD400 LCD Replacement
    1. Canon PowerShot SD400 LCD Replacement, Battery: step 1, image 1 of 2 Canon PowerShot SD400 LCD Replacement, Battery: step 1, image 2 of 2
      • Slide the battery cover open (indicated by the red box).
      Ask FixBot
    2. Canon PowerShot SD400 LCD Replacement: step 2, image 1 of 1
      • Push in the orange clip (indicated by the red box) to eject the battery.
      Ask FixBot
    3. Canon PowerShot SD400 LCD Replacement: step 3, image 1 of 1
      • Insert the charged battery back into the slot.
      • Close the cover.
      Ask FixBot
    1. Canon PowerShot SD400 LCD Replacement, LCD: step 4, image 1 of 3 Canon PowerShot SD400 LCD Replacement, LCD: step 4, image 2 of 3 Canon PowerShot SD400 LCD Replacement, LCD: step 4, image 3 of 3
      • Locate these six screws that need to be removed to open the camera’s housing. These screws can be found on the bottom and both sides of the camera.
      Ask FixBot
    2. Canon PowerShot SD400 LCD Replacement: step 5, image 1 of 3 Canon PowerShot SD400 LCD Replacement: step 5, image 2 of 3 Canon PowerShot SD400 LCD Replacement: step 5, image 3 of 3
      • Using the screwdriver, carefully remove the exterior screws and place them in a safe location to avoid misplacing them.
      Ask FixBot
    3. Canon PowerShot SD400 LCD Replacement: step 6, image 1 of 2 Canon PowerShot SD400 LCD Replacement: step 6, image 2 of 2
      • Locate the interior screw that is above the top right of the LCD screen.
      • Remove the screw using the screwdriver.
      Ask FixBot
    4. Canon PowerShot SD400 LCD Replacement: step 7, image 1 of 3 Canon PowerShot SD400 LCD Replacement: step 7, image 2 of 3 Canon PowerShot SD400 LCD Replacement: step 7, image 3 of 3
      • Locate the two clips on the left side of the LCD screen.
      • Carefully insert the tip of a flat-head screwdriver under the two clips of the LCD screen.
      • Slowly lift the screen using the flat-head screwdriver.
      • Potential for device damage Lift the screen gently to avoid any damage.
      Ask FixBot
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
2 other people completed this guide.
Yi Huang Ke
51 Reputation
4 Guides authored
James Madison, Team 1-1, Allen Fall 2011 Member of James Madison, Team 1-1, Allen Fall 2011
JMU-ALLEN-F11S1G1
4 Members
48 Guides authored
1 Guide Comment
Do you carry a lcd screen for the Powershot sd400?
Jesus Licon - Reply Share
Past 24 Hours: 4
Past 7 Days: 12
Past 30 Days: 54
All Time: 4,103
