Up to 20% off select tools
Canon PowerShot SD30 Screen Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
11
Past 30 Days:
66
All Time:
659
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 20 - 35 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
If your Canon PowerShot SD30 is showing a flickering, distorted, cracked, or completely blank display, use this guide to replace the rear LCD screen. The LCD allows you to review photos, frame shots, and navigate settings—so when it fails, normal use of the camera becomes difficult or impossible.
Common symptoms of a failing screen include no image output, unresponsive or partially lit areas, color distortion, or visible physical damage. For help identifying these issues, refer to the relevant sections of the PowerShot SD30 Troubleshooting page.
Before beginning the repair, make sure to power off the camera and remove the battery and memory card. If your existing screen is cracked or shattered, take care when handling broken glass. Because this guide involves opening the camera’s casing and exposing internal components, an ESD-safe work area is recommended to prevent static damage.
This guide will walk you step-by-step through removing the damaged LCD and installing a replacement screen, allowing you to restore full display functionality and get your Canon PowerShot SD30 working properly again.
    1. Canon PowerShot SD30 Screen Replacement, Front Cover: step 1, image 1 of 2 Canon PowerShot SD30 Screen Replacement, Front Cover: step 1, image 2 of 2
      • Be sure to remove the wrist strap and battery before removing the cover.
      • Remove the two 2mm black screws that are located on the underside of the camera.
      • Remove the two 3mm silver screws from the right side of camera.
      Ask FixBot
    2. Canon PowerShot SD30 Screen Replacement: step 2, image 1 of 1
      • Gently remove the front cover.
      Ask FixBot
    1. Canon PowerShot SD30 Screen Replacement, Back Cover: step 3, image 1 of 3 Canon PowerShot SD30 Screen Replacement, Back Cover: step 3, image 2 of 3 Canon PowerShot SD30 Screen Replacement, Back Cover: step 3, image 3 of 3
      • Remove the wrist strap and battery before removing the back cover.
      • Remove the 2mm screw from the back of the camera.
      • Remove two 2mm screws from the bottom of the camera.
      • Remove two 2mm screws the left side of camera.
      Ask FixBot
    2. Canon PowerShot SD30 Screen Replacement: step 4, image 1 of 1
      • Gently remove the back cover.
      Ask FixBot
    1. Canon PowerShot SD30 Screen Replacement, Screen: step 5, image 1 of 2 Canon PowerShot SD30 Screen Replacement, Screen: step 5, image 2 of 2
      • Remove top button panel by removing the screw located at the top right of the panel.
      Ask FixBot
    2. Canon PowerShot SD30 Screen Replacement: step 6, image 1 of 2 Canon PowerShot SD30 Screen Replacement: step 6, image 2 of 2
      • Remove screws both at the top and the base of the screen to free the screen.
      Ask FixBot
    3. Canon PowerShot SD30 Screen Replacement: step 7, image 1 of 3 Canon PowerShot SD30 Screen Replacement: step 7, image 2 of 3 Canon PowerShot SD30 Screen Replacement: step 7, image 3 of 3
      Tool used on this step:
      Buy
      • Use tweezers to lift the tab that secures the screen wire and remove.
      • You need to do this for both wires.
      Ask FixBot
2 other people completed this guide.
Author
with
Erin Brophy
124 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 11
Past 30 Days: 66
All Time: 659
