Up to 20% off select tools
Canon PowerShot SD30 Control Panel Replacement
View statistics:
Past 24 Hours:
3
Past 7 Days:
10
Past 30 Days:
67
All Time:
795
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 - 15 minutes
Difficulty: Moderate
Featured Student Guide
This guide has been the hard work of our awesome students and is found to be exceptionally cool by the iFixit staff.
Tools
Introduction
Go to step 1 ↓
Use this guide to replace the control panel in your camera.
    1. Canon PowerShot SD30 Control Panel Replacement, Front Cover: step 1, image 1 of 2 Canon PowerShot SD30 Control Panel Replacement, Front Cover: step 1, image 2 of 2
      • Be sure to remove the wrist strap and battery before removing the cover.
      • Remove the two 2mm black screws that are located on the underside of the camera.
      • Remove the two 3mm silver screws from the right side of camera.
      Ask FixBot
    2. Canon PowerShot SD30 Control Panel Replacement: step 2, image 1 of 1
      • Gently remove the front cover.
      Ask FixBot
    1. Canon PowerShot SD30 Control Panel Replacement, Back Cover: step 3, image 1 of 3 Canon PowerShot SD30 Control Panel Replacement, Back Cover: step 3, image 2 of 3 Canon PowerShot SD30 Control Panel Replacement, Back Cover: step 3, image 3 of 3
      • Remove the wrist strap and battery before removing the back cover.
      • Remove the 2mm screw from the back of the camera.
      • Remove two 2mm screws from the bottom of the camera.
      • Remove two 2mm screws the left side of camera.
      Ask FixBot
    2. Canon PowerShot SD30 Control Panel Replacement: step 4, image 1 of 1
      • Gently remove the back cover.
      Ask FixBot
    1. Canon PowerShot SD30 Control Panel Replacement, Control Panel: step 5, image 1 of 3 Canon PowerShot SD30 Control Panel Replacement, Control Panel: step 5, image 2 of 3 Canon PowerShot SD30 Control Panel Replacement, Control Panel: step 5, image 3 of 3
      Tool used on this step:
      Buy
      • Use the tweezers to pull up on the piece of black plastic connected to the ribbon to unhook and remove the ribbon connected to the screen.
      • You also have to pull up on the top part of the control panel because it is connected to the metal by a sticky pad.
      Ask FixBot
    2. Canon PowerShot SD30 Control Panel Replacement: step 6, image 1 of 3 Canon PowerShot SD30 Control Panel Replacement: step 6, image 2 of 3 Canon PowerShot SD30 Control Panel Replacement: step 6, image 3 of 3
      • Turn the camera over to the side with the lens and remove the ribbon on the left side.
      • After removing the ribbon there will be a second ribbon to remove that was hiding underneath the first ribbon.
      Ask FixBot
    3. Canon PowerShot SD30 Control Panel Replacement: step 7, image 1 of 1
      • Lift up the button that connects to the power button of the camera so you can remove the control panel.
      Ask FixBot
    4. Canon PowerShot SD30 Control Panel Replacement: step 8, image 1 of 1
      • Remove the control panel from the camera.
      Ask FixBot
2 other people completed this guide.
Author
with
Diego Hughes
139 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 10
Past 30 Days: 67
All Time: 795
