Canon PowerShot SD1300 IS Shutter Button Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
14
Past 30 Days:
82
All Time:
782
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 - 20 minutes
Difficulty: Moderate
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Needs More Images
A few more images would make this guide's procedures crystal clear.
Introduction
Go to step 1 ↓
This guide will show you how to properly replace a faulty shutter button.
Tools
    1. Canon PowerShot SD1300 IS Shutter Button Replacement, Shutter Button: step 1, image 1 of 3 Canon PowerShot SD1300 IS Shutter Button Replacement, Shutter Button: step 1, image 2 of 3 Canon PowerShot SD1300 IS Shutter Button Replacement, Shutter Button: step 1, image 3 of 3
      • Remove the two 2mm J00 screws on the right exterior.
      • Remove a single 4 mm J00 on the bottom exterior.
      • Remove a single 3mm J00 on the left exterior.
      Ask FixBot
    2. Canon PowerShot SD1300 IS Shutter Button Replacement: step 2, image 1 of 1
      • Once the front shell of the camera is removed the back shell should slide off just the same.
      Ask FixBot
    3. Canon PowerShot SD1300 IS Shutter Button Replacement: step 3, image 1 of 1
      Tool used on this step:
      Heavy-Duty Spudger
      Buy
      Ask FixBot
    4. Canon PowerShot SD1300 IS Shutter Button Replacement: step 4, image 1 of 1
      • Insert Heavy-Duty Spudger under shutter button to release shutter button.
      Ask FixBot
Clayton
584 Reputation
5 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 14
Past 30 Days: 82
All Time: 782
