Canon PowerShot SD1300 IS Lens Replacement
  1. Canon PowerShot SD1300 IS Lens Replacement, Lens: step 1, image 1 of 3 Canon PowerShot SD1300 IS Lens Replacement, Lens: step 1, image 2 of 3 Canon PowerShot SD1300 IS Lens Replacement, Lens: step 1, image 3 of 3
    • Remove the two 2mm J00 screws on the right exterior.
    • Remove a single 4 mm J00 on the bottom exterior.
    • Remove a single 3mm J00 on the left exterior.
    • Remove a single 2mm J00 screw on the left exterior hidden under the A/V Out port.
    Ask FixBot
  2. Canon PowerShot SD1300 IS Lens Replacement: step 2, image 1 of 1
    • Once the front shell of the camera is removed the back shell should slide off just the same.
    Ask FixBot
  3. Canon PowerShot SD1300 IS Lens Replacement: step 3, image 1 of 1
    • Use one of your plastic opening tools to separate the screen from the main body of your PowerShot.
    Ask FixBot
  4. Canon PowerShot SD1300 IS Lens Replacement: step 4, image 1 of 1
    • Remove five of the 3mm J00 screws under the screen to release the lens for replacement.
    • Lens assembly should be removed through the front of the camera once screws are removed.
    Ask FixBot
3 other people completed this guide.
Clayton
584 Reputation
5 Guides authored
1 Guide Comment
I have a SD1300 IS and it has another case screw beneath a plastic cover just below the USB port.
Also step 4 shows 2 screws to remove on the lens that do not go through the metal frame. These should not be removed for lens removal.
It is necessary on mine to remove the 2 screws on the left side of the metal frame that attach to the lens assy.
Greg Reinhart - Reply Share
Past 24 Hours: 1
Past 7 Days: 12
Past 30 Days: 72
All Time: 2,655
