Canon PowerShot SD1100 IS Function Buttons Replacement
Views: 2.6K
View statistics:
Past 24 Hours:
2
Past 7 Days:
20
Past 30 Days:
105
All Time:
2,610
Comments: 3
3 comments on steps.
Completed: 0
Favorites: 0
Time Required: 20 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
This guide should be used if our guide, "Cleaning Function Buttons", doesn't fix your function buttons.
Tools
  • Spudger
    4.9
  • Tweezers
    1. Canon PowerShot SD1100 IS Function Buttons Replacement, Front and Rear Cover: step 1, image 1 of 2 Canon PowerShot SD1100 IS Function Buttons Replacement, Front and Rear Cover: step 1, image 2 of 2
      • Remove wrist strap and battery.
      Ask FixBot
    2. Canon PowerShot SD1100 IS Function Buttons Replacement: step 2, image 1 of 3 Canon PowerShot SD1100 IS Function Buttons Replacement: step 2, image 2 of 3 Canon PowerShot SD1100 IS Function Buttons Replacement: step 2, image 3 of 3
      • Remove 2 screws from each side of the camera (4 total, 0.102 in).
      • Remove 2 screws from the bottom on the camera (0.138 in).
      • Do not mix the 4 side screws with the 2 bottoms ones; they are different sizes.
      Ask FixBot
    3. Canon PowerShot SD1100 IS Function Buttons Replacement: step 3, image 1 of 3 Canon PowerShot SD1100 IS Function Buttons Replacement: step 3, image 2 of 3 Canon PowerShot SD1100 IS Function Buttons Replacement: step 3, image 3 of 3
      • Gently pull off the front cover.
      • The plate on the side should come off.
      • Gently pull off the back cover.
      Ask FixBot
    4. Canon PowerShot SD1100 IS Function Buttons Replacement: step 4, image 1 of 1
      • The cases should now be removed.
      Ask FixBot
    1. Canon PowerShot SD1100 IS Function Buttons Replacement, Top Button Assembly: step 5, image 1 of 1
      • Use the spudger to disconnect the black tab.
      Ask FixBot
    2. Canon PowerShot SD1100 IS Function Buttons Replacement: step 6, image 1 of 1
      • Gently pull off the shutter button assembly.
      Ask FixBot
    3. Canon PowerShot SD1100 IS Function Buttons Replacement: step 7, image 1 of 1
      Tool used on this step:
      Buy
      • Use the tweezers to disconnect the microphone cable.
      Ask FixBot
    4. Canon PowerShot SD1100 IS Function Buttons Replacement: step 8, image 1 of 1
      • The shutter button assembly should now be removed.
      Ask FixBot
    1. Canon PowerShot SD1100 IS Function Buttons Replacement, Function Buttons: step 9, image 1 of 1
      • With the spudger, flip up the black tab on the main ribbon.
      Ask FixBot
    2. Canon PowerShot SD1100 IS Function Buttons Replacement: step 10, image 1 of 2 Canon PowerShot SD1100 IS Function Buttons Replacement: step 10, image 2 of 2
      • Gently pull straight out on the ribbon to disconnect it from the logic board.
      Ask FixBot
    3. Canon PowerShot SD1100 IS Function Buttons Replacement: step 11, image 1 of 1
      • By hand, gently unfold the function button board and lift it off the frame.
      Ask FixBot
    4. Canon PowerShot SD1100 IS Function Buttons Replacement: step 12, image 1 of 1
      • Congratulations! The function button board can now be replaced.
      Ask FixBot
Wyatt Chan
235 Reputation
2 Guides authored
Cal Poly, Team 3-32, Regan Winter 2011 Member of Cal Poly, Team 3-32, Regan Winter 2011
CPSU-REGAN-W11S3G32
3 Members
96 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 20
Past 30 Days: 105
All Time: 2,610
