Up to 20% off select tools
Canon PowerShot SD1000 Shutter Button Replacement
Views: 2K
View statistics:
Past 24 Hours:
5
Past 7 Days:
23
Past 30 Days:
110
All Time:
1,999
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Student In Progress
This guide is being worked on by hardworking students.
Tools
  • Phillips #00 Screwdriver
    4.9
  • Spudger
    4.9
    1. Canon PowerShot SD1000 Shutter Button Replacement, Back Panel: step 1, image 1 of 2 Canon PowerShot SD1000 Shutter Button Replacement, Back Panel: step 1, image 2 of 2
      • Remove the two 2.9 mm screws from the side panel closest to the camera lens.
      Ask FixBot
    2. Canon PowerShot SD1000 Shutter Button Replacement: step 2, image 1 of 1
      • Remove the two 2.9 mm screws from the camera bottom panel.
      Ask FixBot
    3. Canon PowerShot SD1000 Shutter Button Replacement: step 3, image 1 of 1
      • Remove the two 2.9 mm screws from the side panel farthest from the lens.
      Ask FixBot
    4. Canon PowerShot SD1000 Shutter Button Replacement: step 4, image 1 of 1
      • Pull the back panel away from the camera body, starting at the end with the function buttons.
      Ask FixBot
    5. Canon PowerShot SD1000 Shutter Button Replacement: step 5, image 1 of 1
      • Remove the small cover panel and the attached wrist strap mount.
      Ask FixBot
    1. Canon PowerShot SD1000 Shutter Button Replacement, Front Case: step 6, image 1 of 1
      • Remove the front cover by gently pulling it away from the camera body.
      Ask FixBot
    2. Canon PowerShot SD1000 Shutter Button Replacement: step 7, image 1 of 1
      • Place the front cover, back cover, and wrist strap mount in a safe place until you are ready for reassembly.
      Ask FixBot
    1. Canon PowerShot SD1000 Shutter Button Replacement, Shutter Button: step 8, image 1 of 2 Canon PowerShot SD1000 Shutter Button Replacement, Shutter Button: step 8, image 2 of 2
      • Using the spudger, take off the shutter button by prying the small tab on the front side of the camera.
      Ask FixBot
Author
with
Phillip Phung
666 Reputation
9 Guides authored
Cal Poly, Team 8-18, Maness Winter 2012 Member of Cal Poly, Team 8-18, Maness Winter 2012
CPSU-MANESS-W12S8G18
4 Members
120 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 23
Past 30 Days: 110
All Time: 1,999
