Canon PowerShot SD1000 Lens Replacement
    1. Canon PowerShot SD1000 Lens Replacement, Back Panel: step 1, image 1 of 2 Canon PowerShot SD1000 Lens Replacement, Back Panel: step 1, image 2 of 2
      • Remove the two 2.9 mm screws from the side panel closest to the camera lens.
      Ask FixBot
    2. Canon PowerShot SD1000 Lens Replacement: step 2, image 1 of 1
      • Remove the two 2.9 mm screws from the camera bottom panel.
      Ask FixBot
    3. Canon PowerShot SD1000 Lens Replacement: step 3, image 1 of 1
      • Remove the two 2.9 mm screws from the side panel farthest from the lens.
      Ask FixBot
    4. Canon PowerShot SD1000 Lens Replacement: step 4, image 1 of 1
      • Pull the back panel away from the camera body, starting at the end with the function buttons.
      Ask FixBot
    5. Canon PowerShot SD1000 Lens Replacement: step 5, image 1 of 1
      • Remove the small cover panel and the attached wrist strap mount.
      Ask FixBot
    1. Canon PowerShot SD1000 Lens Replacement, Front Case: step 6, image 1 of 1
      • Remove the front cover by gently pulling it away from the camera body.
      Ask FixBot
    2. Canon PowerShot SD1000 Lens Replacement: step 7, image 1 of 1
      • Place the front cover, back cover, and wrist strap mount in a safe place until you are ready for reassembly.
      Ask FixBot
    1. Canon PowerShot SD1000 Lens Replacement, LCD Screen: step 8, image 1 of 1
      • Remove the two 2.4 mm screws located at the top of the LCD panel.
      Ask FixBot
    2. Canon PowerShot SD1000 Lens Replacement: step 9, image 1 of 2 Canon PowerShot SD1000 Lens Replacement: step 9, image 2 of 2
      • Pull up the metal frame surrounding the LCD screen starting at the side of the camera.
      Ask FixBot
    3. Canon PowerShot SD1000 Lens Replacement: step 10, image 1 of 1
      • Push the metal frame away from the metal tab using the spudger to detach the frame.
      • Rotate the metal frame upwards.
      • The metal framing should be attached by a metal tab towards the bottom of the camera, near the function buttons.
      Ask FixBot
    4. Canon PowerShot SD1000 Lens Replacement: step 11, image 1 of 2 Canon PowerShot SD1000 Lens Replacement: step 11, image 2 of 2
      • Carefully lift the metal frame from the camera.
      • Remove the black LCD screen, leaving the thin lens pieces in place.
      • BE CAREFUL; both components are attached by an orange connector ribbon and cannot be removed yet.
      Ask FixBot
    5. Canon PowerShot SD1000 Lens Replacement: step 12, image 1 of 3 Canon PowerShot SD1000 Lens Replacement: step 12, image 2 of 3 Canon PowerShot SD1000 Lens Replacement: step 12, image 3 of 3
      Tool used on this step:
      Buy
      • Carefully pull on the orange connector ribbon to disconnect the LCD screen.
      • The LCD screen can be pulled out of the frame before disconnecting its connector ribbon.
      • Tweezers are helpful to disconnect the ribbon.
      Ask FixBot
    1. Canon PowerShot SD1000 Lens Replacement, Flash Unit: step 13, image 1 of 2 Canon PowerShot SD1000 Lens Replacement, Flash Unit: step 13, image 2 of 2
      • Slide the metal frame off of the camera on the side that is closest to the flash mechanism.
      Ask FixBot
    2. Canon PowerShot SD1000 Lens Replacement: step 14, image 1 of 1
      • Use a Phillips #00 screwdriver to remove the 2.4 mm screw that secures the flash assembly.
      Ask FixBot
    3. Canon PowerShot SD1000 Lens Replacement: step 15, image 1 of 1
      • Use the spudger to gently and carefully disconnect the flash assembly ribbon from the black connector lock.
      Ask FixBot
    4. Canon PowerShot SD1000 Lens Replacement: step 16, image 1 of 2 Canon PowerShot SD1000 Lens Replacement: step 16, image 2 of 2
      • Pull the flash assembly forward out of the camera to remove it.
      • BE CAREFUL when handling the flash assembly. Touching the capacitor (the black cylinder attached to the flash assembly) could shock you.
      Ask FixBot
    1. Canon PowerShot SD1000 Lens Replacement, Lens: step 17, image 1 of 1
      • Remove the 2.90mm screw from the lens, near the motherboard.
      Ask FixBot
    2. Canon PowerShot SD1000 Lens Replacement: step 18, image 1 of 2 Canon PowerShot SD1000 Lens Replacement: step 18, image 2 of 2
      • Using the spudger remove the shutter button by prying the small tab on the front side of the camera.
      Ask FixBot
    3. Canon PowerShot SD1000 Lens Replacement: step 19, image 1 of 2 Canon PowerShot SD1000 Lens Replacement: step 19, image 2 of 2
      • With a spudger disconnect the orange connector ribbon as shown.
      • Disconnect the orange connector ribbon that is located under the now removed shutter button.
      Ask FixBot
    4. Canon PowerShot SD1000 Lens Replacement: step 20, image 1 of 1
      • Remove the two 2.90 mm screws from the motherboard.
      Ask FixBot
    5. Canon PowerShot SD1000 Lens Replacement: step 21, image 1 of 1
      Buy
      • With Tweezers detach the bottom orange ribbon.
      Ask FixBot
    6. Canon PowerShot SD1000 Lens Replacement: step 22, image 1 of 1
      • Remove the screws shown. Start with the outside 6 (3-2.90mm & 3-2.40mm) screws on the metal frame. Then remove the 6 (2.40mm) screws on the back of the lens piece
      Ask FixBot
    7. Canon PowerShot SD1000 Lens Replacement: step 23, image 1 of 1
      • With spudger gently remove the Viewfinder Window that is directly above the lens.
      Ask FixBot
    8. Canon PowerShot SD1000 Lens Replacement: step 24, image 1 of 3 Canon PowerShot SD1000 Lens Replacement: step 24, image 2 of 3 Canon PowerShot SD1000 Lens Replacement: step 24, image 3 of 3
      • Detach the mother board with lens from body of camera.
      • Carefully remove the lens from the motherboard. Use tweezers to remove any of the 4 connecting ribbons from the lens.
      • Your lens has been removed from the motherboard and bottom framing.
      Ask FixBot
4 other people completed this guide.
Phillip Phung
666 Reputation
9 Guides authored
Cal Poly, Team 8-18, Maness Winter 2012 Member of Cal Poly, Team 8-18, Maness Winter 2012
CPSU-MANESS-W12S8G18
4 Members
120 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 15
Past 30 Days: 100
All Time: 6,472
