Canon PowerShot SD1000 LCD Screen Replacement
    1. Canon PowerShot SD1000 LCD Screen Replacement, Back Panel: step 1, image 1 of 2 Canon PowerShot SD1000 LCD Screen Replacement, Back Panel: step 1, image 2 of 2
      • Remove the two 2.9 mm screws from the side panel closest to the camera lens.
      Ask FixBot
    2. Canon PowerShot SD1000 LCD Screen Replacement: step 2, image 1 of 1
      • Remove the two 2.9 mm screws from the camera bottom panel.
      Ask FixBot
    3. Canon PowerShot SD1000 LCD Screen Replacement: step 3, image 1 of 1
      • Remove the two 2.9 mm screws from the side panel farthest from the lens.
      Ask FixBot
    4. Canon PowerShot SD1000 LCD Screen Replacement: step 4, image 1 of 1
      • Pull the back panel away from the camera body, starting at the end with the function buttons.
      Ask FixBot
    5. Canon PowerShot SD1000 LCD Screen Replacement: step 5, image 1 of 1
      • Remove the small cover panel and the attached wrist strap mount.
      Ask FixBot
    1. Canon PowerShot SD1000 LCD Screen Replacement, Front Case: step 6, image 1 of 1
      • Remove the front cover by gently pulling it away from the camera body.
      Ask FixBot
    2. Canon PowerShot SD1000 LCD Screen Replacement: step 7, image 1 of 1
      • Place the front cover, back cover, and wrist strap mount in a safe place until you are ready for reassembly.
      Ask FixBot
    1. Canon PowerShot SD1000 LCD Screen Replacement, LCD Screen: step 8, image 1 of 1
      • Remove the two 2.4 mm screws located at the top of the LCD panel.
      Ask FixBot
    2. Canon PowerShot SD1000 LCD Screen Replacement: step 9, image 1 of 2 Canon PowerShot SD1000 LCD Screen Replacement: step 9, image 2 of 2
      • Pull up the metal frame surrounding the LCD screen starting at the side of the camera.
      Ask FixBot
    3. Canon PowerShot SD1000 LCD Screen Replacement: step 10, image 1 of 1
      • Push the metal frame away from the metal tab using the spudger to detach the frame.
      • Rotate the metal frame upwards.
      • The metal framing should be attached by a metal tab towards the bottom of the camera, near the function buttons.
      Ask FixBot
    4. Canon PowerShot SD1000 LCD Screen Replacement: step 11, image 1 of 2 Canon PowerShot SD1000 LCD Screen Replacement: step 11, image 2 of 2
      • Carefully lift the metal frame from the camera.
      • Remove the black LCD screen, leaving the thin lens pieces in place.
      • BE CAREFUL; both components are attached by an orange connector ribbon and cannot be removed yet.
      Ask FixBot
    5. Canon PowerShot SD1000 LCD Screen Replacement: step 12, image 1 of 3 Canon PowerShot SD1000 LCD Screen Replacement: step 12, image 2 of 3 Canon PowerShot SD1000 LCD Screen Replacement: step 12, image 3 of 3
      Tool used on this step:
      Buy
      • Carefully pull on the orange connector ribbon to disconnect the LCD screen.
      • The LCD screen can be pulled out of the frame before disconnecting its connector ribbon.
      • Tweezers are helpful to disconnect the ribbon.
      Ask FixBot
2 other people completed this guide.
Phillip Phung
666 Reputation
9 Guides authored
Cal Poly, Team 8-18, Maness Winter 2012 Member of Cal Poly, Team 8-18, Maness Winter 2012
CPSU-MANESS-W12S8G18
4 Members
120 Guides authored
1 Guide Comment
Very helpful. These units still sell for a lot more than the cost of the replacement LCD
George Francis - Reply Share
Past 24 Hours: 3
Past 7 Days: 11
Past 30 Days: 72
All Time: 5,186
