Canon PowerShot SD1000 Battery Replacement
Views: 3.6K
View statistics:
Past 24 Hours:
2
Past 7 Days:
17
Past 30 Days:
111
All Time:
3,601
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 1 minute
Difficulty: Easy
Introduction
Go to step 1 ↓
Use this guide to replace the battery on your Canon PowerShot, model SD1000.
When the battery is starting to fail on your Canon PowerShot it may experience drastically shortened battery life or does not turn on at all. Replacing the faulty battery will remedy the problem and ensure that you are able to continue to use your camera as normal.
This guide will walk you through 4 quick and easy steps on how to change your SD1000 battery (A90mAh 3.7V Lithium-Ion).
    1. Canon PowerShot SD1000 Battery Replacement, Battery: step 1, image 1 of 1
      • Turn the camera over so the bottom faces you.
      • Slide the battery cover open.
      Ask FixBot
    2. Canon PowerShot SD1000 Battery Replacement: step 2, image 1 of 1
      • The battery cover should push out.
      • Prop open the battery cover.
      Ask FixBot
    3. Canon PowerShot SD1000 Battery Replacement: step 3, image 1 of 1
      • Let the battery cover open fully and rest as shown.
      Ask FixBot
    4. Canon PowerShot SD1000 Battery Replacement: step 4, image 1 of 1
      • Flip the plastic lever holding the battery as shown.
      • Remove the battery.
      Ask FixBot
Nick Tompkins
52 Reputation
1 Guide authored
Cal Poly, Team 8-18, Maness Winter 2012 Member of Cal Poly, Team 8-18, Maness Winter 2012
CPSU-MANESS-W12S8G18
4 Members
120 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 17
Past 30 Days: 111
All Time: 3,601
