Up to 20% off select tools
Canon PowerShot SD1000 Back Panel Replacement
Views: 2.9K
View statistics:
Past 24 Hours:
4
Past 7 Days:
17
Past 30 Days:
106
All Time:
2,915
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 minutes
Difficulty: Easy
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Tools
Introduction
Go to step 1 ↓
The back panel of the Canon PowerShot SD1000 protects the internal components and adds to the overall aesthetic. Over time the back panel may receive wear and tear, cracks, and other damages that need replacement. Properly replacing the back panel increases the lifespan of your camera.
Before using this guide, please look over the back panel for corrosion or metal shards. This can cause a safety hazard when opening the back panel. If found, please wear protective gloves to avoid direct skin contact.
This manual will show you step-by-step instructions for replacing the back panel, safety precautions, highlight tools needed, and tips to achieve a professional result.
    1. Canon PowerShot SD1000 Back Panel Replacement, Back Panel: step 1, image 1 of 2 Canon PowerShot SD1000 Back Panel Replacement, Back Panel: step 1, image 2 of 2
      • Remove the two 2.9 mm screws from the side panel closest to the camera lens.
      Ask FixBot
    2. Canon PowerShot SD1000 Back Panel Replacement: step 2, image 1 of 1
      • Remove the two 2.9 mm screws from the camera bottom panel.
      Ask FixBot
    3. Canon PowerShot SD1000 Back Panel Replacement: step 3, image 1 of 1
      • Remove the two 2.9 mm screws from the side panel farthest from the lens.
      Ask FixBot
    4. Canon PowerShot SD1000 Back Panel Replacement: step 4, image 1 of 1
      • Pull the back panel away from the camera body, starting at the end with the function buttons.
      Ask FixBot
    5. Canon PowerShot SD1000 Back Panel Replacement: step 5, image 1 of 1
      • Remove the small cover panel and the attached wrist strap mount.
      Ask FixBot
Author
with
Phillip Phung
666 Reputation
9 Guides authored
Cal Poly, Team 8-18, Maness Winter 2012 Member of Cal Poly, Team 8-18, Maness Winter 2012
CPSU-MANESS-W12S8G18
4 Members
120 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 17
Past 30 Days: 106
All Time: 2,915
