Canon PowerShot S80 Motherboard Replacement
  1. Canon PowerShot S80 Motherboard Replacement, Outer Casing: step 1, image 1 of 2 Canon PowerShot S80 Motherboard Replacement, Outer Casing: step 1, image 2 of 2
    • Remove the knot on the wrist lanyard.
    • Remove the battery and the memory card.
    Ask FixBot
  2. Canon PowerShot S80 Motherboard Replacement: step 2, image 1 of 2 Canon PowerShot S80 Motherboard Replacement: step 2, image 2 of 2
    • Begin removing the screws on the bottom of the outer casing.
    • Next, remove the rest of the screws from the outer casing.
    Ask FixBot
  3. Canon PowerShot S80 Motherboard Replacement: step 3, image 1 of 3 Canon PowerShot S80 Motherboard Replacement: step 3, image 2 of 3 Canon PowerShot S80 Motherboard Replacement: step 3, image 3 of 3
    • Gently pull the front cover off of the camera.
    Ask FixBot
  4. Canon PowerShot S80 Motherboard Replacement: step 4, image 1 of 3 Canon PowerShot S80 Motherboard Replacement: step 4, image 2 of 3 Canon PowerShot S80 Motherboard Replacement: step 4, image 3 of 3
    • Open the "A/V Out Digital" cover. Remove the screw inside.
    • Gently pull off the back casing.
    • Remove the black "L" shaped piece of metal.
    Ask FixBot
  5. Canon PowerShot S80 Motherboard Replacement, LCD Screen: step 5, image 1 of 1
    • Remove the three screws that are holding the screen in place. Free the screen from the underlying components.
    • Be careful with the ribbon wire that is still attached on the left side of the screen.
    Ask FixBot
  6. Canon PowerShot S80 Motherboard Replacement: step 6, image 1 of 2 Canon PowerShot S80 Motherboard Replacement: step 6, image 2 of 2
    • With the spudger, gently lift the black flap that is holding the wide ribbon cable wire in place.
    • Unplug the wide ribbon cable.
    • Unplug the narrow ribbon cable to free the LCD screen from the camera body.
    Ask FixBot
  7. Canon PowerShot S80 Motherboard Replacement, Motherboard: step 7, image 1 of 1
    • Remove the screws holding down the function set button.
    Ask FixBot
  8. Canon PowerShot S80 Motherboard Replacement: step 8, image 1 of 1
    • Gently pry up the tab with a metal spudger and remove the ribbon cable.
    Ask FixBot
  9. Canon PowerShot S80 Motherboard Replacement: step 9, image 1 of 1
    • Be mindful of the pins as you lift up and remove the function/set button.
    Ask FixBot
  10. Canon PowerShot S80 Motherboard Replacement: step 10, image 1 of 3 Canon PowerShot S80 Motherboard Replacement: step 10, image 2 of 3 Canon PowerShot S80 Motherboard Replacement: step 10, image 3 of 3
    • Remove the screws from the metal plate.
    • Gently remove the metal plate.
    Ask FixBot
  11. Canon PowerShot S80 Motherboard Replacement: step 11, image 1 of 2 Canon PowerShot S80 Motherboard Replacement: step 11, image 2 of 2
    • Lift the tab connecting the ribbon cable and detach.
    Ask FixBot
  12. Canon PowerShot S80 Motherboard Replacement: step 12, image 1 of 2 Canon PowerShot S80 Motherboard Replacement: step 12, image 2 of 2
    • Use a spudger to lift up the ribbon cable tab.
    • Detach the ribbon cable.
    Ask FixBot
  13. Canon PowerShot S80 Motherboard Replacement: step 13, image 1 of 2 Canon PowerShot S80 Motherboard Replacement: step 13, image 2 of 2
    • Gently remove the entire ribbon cable connection to release the ribbon cable from the camera.
    Ask FixBot
  14. Canon PowerShot S80 Motherboard Replacement: step 14, image 1 of 1
    • Unscrew the circuit board from the flash unit.
    Ask FixBot
  15. Canon PowerShot S80 Motherboard Replacement: step 15, image 1 of 3 Canon PowerShot S80 Motherboard Replacement: step 15, image 2 of 3 Canon PowerShot S80 Motherboard Replacement: step 15, image 3 of 3
    • Pry up the ribbon cable connection and remove it from the camera.
    • Lift the ribbon cable tab and completely detach the cable from the camera.
    Ask FixBot
  16. Canon PowerShot S80 Motherboard Replacement: step 16, image 1 of 1
    • Pry up the connection, being mindful of the light adhesive.
    Ask FixBot
  17. Canon PowerShot S80 Motherboard Replacement: step 17, image 1 of 1
    • Remove the last screw holding the motherboard to the main body.
    Ask FixBot
  18. Canon PowerShot S80 Motherboard Replacement: step 18, image 1 of 2 Canon PowerShot S80 Motherboard Replacement: step 18, image 2 of 2
    • Use a spudger to gently lift the motherboard from the camera.
    Ask FixBot
2 other people completed this guide.
BrettH
219 Reputation
5 Guides authored
Cal Poly, Team 19-5, Maness SU 2012 Member of Cal Poly, Team 19-5, Maness SU 2012
CPSU-MANESS-SU12S19G5
1 Member
5 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 32
All Time: 4,903
