Up to 20% off select tools
Canon PowerShot S80 Flash Replacement
Views: 4.5K
View statistics:
Past 24 Hours:
4
Past 7 Days:
16
Past 30 Days:
93
All Time:
4,473
Comments: 2
2 comments on steps.
Completed: 0
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 30 - 45 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
This guide serves to replace a faulty flash mechanism.
    1. Canon PowerShot S80 Flash Replacement, Outer Casing: step 1, image 1 of 2 Canon PowerShot S80 Flash Replacement, Outer Casing: step 1, image 2 of 2
      • Remove the knot on the wrist lanyard.
      • Remove the battery and the memory card.
      Ask FixBot
    2. Canon PowerShot S80 Flash Replacement: step 2, image 1 of 2 Canon PowerShot S80 Flash Replacement: step 2, image 2 of 2
      • Begin removing the screws on the bottom of the outer casing.
      • Next, remove the rest of the screws from the outer casing.
      Ask FixBot
    3. Canon PowerShot S80 Flash Replacement: step 3, image 1 of 3 Canon PowerShot S80 Flash Replacement: step 3, image 2 of 3 Canon PowerShot S80 Flash Replacement: step 3, image 3 of 3
      • Gently pull the front cover off of the camera.
      Ask FixBot
    4. Canon PowerShot S80 Flash Replacement: step 4, image 1 of 3 Canon PowerShot S80 Flash Replacement: step 4, image 2 of 3 Canon PowerShot S80 Flash Replacement: step 4, image 3 of 3
      • Open the "A/V Out Digital" cover. Remove the screw inside.
      • Gently pull off the back casing.
      • Remove the black "L" shaped piece of metal.
      Ask FixBot
    1. Canon PowerShot S80 Flash Replacement, LCD Screen: step 5, image 1 of 1
      • Remove the three screws that are holding the screen in place. Free the screen from the underlying components.
      • Be careful with the ribbon wire that is still attached on the left side of the screen.
      Ask FixBot
    2. Canon PowerShot S80 Flash Replacement: step 6, image 1 of 2 Canon PowerShot S80 Flash Replacement: step 6, image 2 of 2
      • With the spudger, gently lift the black flap that is holding the wide ribbon cable wire in place.
      • Unplug the wide ribbon cable.
      • Unplug the narrow ribbon cable to free the LCD screen from the camera body.
      Ask FixBot
    1. Canon PowerShot S80 Flash Replacement, Flash: step 7, image 1 of 1
      • Remove the L-shaped corner trim containing the picture button.
      • Carefully unplug the connection cable that is attached.
      Ask FixBot
    2. Canon PowerShot S80 Flash Replacement: step 8, image 1 of 2 Canon PowerShot S80 Flash Replacement: step 8, image 2 of 2
      Tool used on this step:
      Buy
      • Pull the selector wheel from the top corner of the camera.
      • Carefully remove the ribbon cable connection with a set of tweezers.
      Ask FixBot
    3. Canon PowerShot S80 Flash Replacement: step 9, image 1 of 1
      • With a Phillips #00 Screwdriver, unscrew the zoom toggle switch and remove it from the camera.
      Ask FixBot
    4. Canon PowerShot S80 Flash Replacement: step 10, image 1 of 1
      • With a Phillips #00 Screwdriver, unscrew the flash board.
      Ask FixBot
    5. Canon PowerShot S80 Flash Replacement: step 11, image 1 of 1
      • Remove the cable connection. With a metal spudger, gently pry up.
      • Remove the ribon cable. With a metal spudger, gently lift up the black tab.
      Ask FixBot
    6. Canon PowerShot S80 Flash Replacement: step 12, image 1 of 1
      • Lift the flash bulb unit upwards from the camera.
      Ask FixBot
    7. Canon PowerShot S80 Flash Replacement: step 13, image 1 of 2 Canon PowerShot S80 Flash Replacement: step 13, image 2 of 2
      • Lift the entire three-part flash assembly from the camera.
      Ask FixBot
Author
with
BrettH
219 Reputation
5 Guides authored
Cal Poly, Team 19-5, Maness SU 2012 Member of Cal Poly, Team 19-5, Maness SU 2012
CPSU-MANESS-SU12S19G5
1 Member
60 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 16
Past 30 Days: 93
All Time: 4,473
