Canon PowerShot S500 LCD Replacement
    1. Canon PowerShot S500 LCD Replacement, Front and Rear Casing : step 1, image 1 of 2 Canon PowerShot S500 LCD Replacement, Front and Rear Casing : step 1, image 2 of 2
      • Unscrew five Phillips screws using a #0 Phillips screwdriver.
      • One screw is on upper right corner of the back panel.
      • The other four screws are on the bottom of the camera.
      Ask FixBot
    2. Canon PowerShot S500 LCD Replacement: step 2, image 1 of 1
      • Open the memory card cover by moving the slide switch toward the top end of of the camera.
      • Remove the memory card from the slot.
      Ask FixBot
    3. Canon PowerShot S500 LCD Replacement: step 3, image 1 of 1
      • Remove the rear cover from the rest of the camera.
      • This may require gentle rocking of the case to free it.
      Ask FixBot
    4. Canon PowerShot S500 LCD Replacement: step 4, image 1 of 2 Canon PowerShot S500 LCD Replacement: step 4, image 2 of 2
      • Unscrew the four Phillips screws from the side of the casing and one screw from the bottom using a #0 Phillips screwdriver.
      Ask FixBot
    5. Canon PowerShot S500 LCD Replacement: step 5, image 1 of 1
      • Free the front cover from the rest of the camera.
      • The cover may require gentle rocking to remove.
      Ask FixBot
    1. Canon PowerShot S500 LCD Replacement, LCD: step 6, image 1 of 1
      • Unscrew two Phillips screws above the LCD using a #0 Phillips screwdriver.
      Ask FixBot
    2. Canon PowerShot S500 LCD Replacement: step 7, image 1 of 1
      • Gently separate the top of LCD from the rest of the camera using your thumb.
      • Be careful not pull the LCD too far because of the ribbon cable connection.
      • Place the Spudger in the hole of the electrical ribbon.
      • Gently pull the ribbon down using the Spudger until it is free from the camera but still connected to the LCD.
      • The LCD will still be connected to the rest of the camera
      Ask FixBot
    3. Canon PowerShot S500 LCD Replacement: step 8, image 1 of 2 Canon PowerShot S500 LCD Replacement: step 8, image 2 of 2
      • Unscrew single Phillips screw with a #0 Phillips screwdriver.
      • Free the bottom panel and attached ribbon from the rest of the camera.
      • Be careful not to damage the ribbon.
      Ask FixBot
    4. Canon PowerShot S500 LCD Replacement: step 9, image 1 of 1
      • Turn over the camera.
      • Lift the clear plastic from the face of the camera, peeling the adhesive just below the zoom lens.
      • The plastic will still be connected on the left side.
      Ask FixBot
    5. Canon PowerShot S500 LCD Replacement: step 10, image 1 of 1
      • Place the Spudger between the orange ribbon and the black ribbon gate.
      • Lift the ribbon gate using the Spudger.
      Ask FixBot
    6. Canon PowerShot S500 LCD Replacement: step 11, image 1 of 1
      • Place the Spudger in the corner of the ribbon above the hole.
      • Remove the ribbon from the ribbon gate by pulling the Spudger away from the gate.
      Ask FixBot
    7. Canon PowerShot S500 LCD Replacement: step 12, image 1 of 1
      • Free this ribbon and the bottom panel from the rest of the camera.
      Ask FixBot
    8. Canon PowerShot S500 LCD Replacement: step 13, image 1 of 1
      • Turn the camera over so you can see the LCD.
      • Remove single Phillips screw below the LCD using a #0 Phillips screwdriver.
      Ask FixBot
    9. Canon PowerShot S500 LCD Replacement: step 14, image 1 of 1
      • Lift the blue ribbon gate using the Spudger.
      Ask FixBot
    10. Canon PowerShot S500 LCD Replacement: step 15, image 1 of 1
      • Insert the Spudger into the hole of the ribbon.
      • Move the Spudger away from the gate to fully remove ribbon.
      Ask FixBot
    11. Canon PowerShot S500 LCD Replacement: step 16, image 1 of 1
      • Lift the LCD away from the rest of the camera.
      Ask FixBot
Nathan Balcom
102 Reputation
8 Guides authored
Cal Poly, Team 16-28, Maness Winter 2010 Member of Cal Poly, Team 16-28, Maness Winter 2010
CPSU-MANESS-W10S16G28
4 Members
96 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 19
All Time: 3,695
