Canon PowerShot S500 Front and Rear Casing Replacement
  1. Canon PowerShot S500 Front and Rear Casing  Replacement, Front and Rear Casing : step 1, image 1 of 2 Canon PowerShot S500 Front and Rear Casing  Replacement, Front and Rear Casing : step 1, image 2 of 2
    • Unscrew five Phillips screws using a #0 Phillips screwdriver.
    • One screw is on upper right corner of the back panel.
    • The other four screws are on the bottom of the camera.
    Ask FixBot
  2. Canon PowerShot S500 Front and Rear Casing  Replacement: step 2, image 1 of 1
    • Open the memory card cover by moving the slide switch toward the top end of of the camera.
    • Remove the memory card from the slot.
    Ask FixBot
  3. Canon PowerShot S500 Front and Rear Casing  Replacement: step 3, image 1 of 1
    • Remove the rear cover from the rest of the camera.
    • This may require gentle rocking of the case to free it.
    Ask FixBot
  4. Canon PowerShot S500 Front and Rear Casing  Replacement: step 4, image 1 of 2 Canon PowerShot S500 Front and Rear Casing  Replacement: step 4, image 2 of 2
    • Unscrew the four Phillips screws from the side of the casing and one screw from the bottom using a #0 Phillips screwdriver.
    Ask FixBot
  5. Canon PowerShot S500 Front and Rear Casing  Replacement: step 5, image 1 of 1
    • Free the front cover from the rest of the camera.
    • The cover may require gentle rocking to remove.
    Ask FixBot
Finish Line
Nathan Balcom
102 Reputation
8 Guides authored
Cal Poly, Team 16-28, Maness Winter 2010 Member of Cal Poly, Team 16-28, Maness Winter 2010
CPSU-MANESS-W10S16G28
4 Members
9 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 41
All Time: 2,036
