Canon PowerShot S50 Front Panel/Battery Door Replacement
    1. Canon PowerShot S50 Front Panel/Battery Door Replacement, Battery: step 1, image 1 of 2 Canon PowerShot S50 Front Panel/Battery Door Replacement, Battery: step 1, image 2 of 2
      • Place camera LCD side up and press up on the battery door.
      • Let it swing open until you can see the battery inside.
      Ask FixBot
    2. Canon PowerShot S50 Front Panel/Battery Door Replacement: step 2, image 1 of 1
      • Press down on the orange plastic.
      • This will gently eject the battery from its compartment.
      Ask FixBot
    3. Canon PowerShot S50 Front Panel/Battery Door Replacement: step 3, image 1 of 2 Canon PowerShot S50 Front Panel/Battery Door Replacement: step 3, image 2 of 2
      • Holding the edges, slide out the battery.
      Ask FixBot
    1. Canon PowerShot S50 Front Panel/Battery Door Replacement, Front Panel/Battery Door: step 4, image 1 of 1
      • Look at the camera from the side with the lanyard and 4 screws.
      • Remove the two 3.4 mm screws on the metallic colored part.
      Ask FixBot
    2. Canon PowerShot S50 Front Panel/Battery Door Replacement: step 5, image 1 of 1
      • Remove the 3mm screw on the top left.
      • NOTE: When reassembling, it is helpful to put the top screw back in before placing the front cover back on the camera.
      • Now remove the 5.3mm screw on the bottom.
      Ask FixBot
    3. Canon PowerShot S50 Front Panel/Battery Door Replacement: step 6, image 1 of 1
      • Place the camera LCD side down.
      • Remove the two 5.3mm screws by the battery door.
      Ask FixBot
    4. Canon PowerShot S50 Front Panel/Battery Door Replacement: step 7, image 1 of 1
      • Remove the four 3.4mm screws on the bottom of the camera around the tripod mount.
      • Make sure to keep these screws separate from the previous 5.3 mm screws.
      Ask FixBot
    5. Canon PowerShot S50 Front Panel/Battery Door Replacement: step 8, image 1 of 1
      • Stand the camera back up.
      • Remove the two 3.6mm screws on the side with the A/V Out port.
      Ask FixBot
    6. Canon PowerShot S50 Front Panel/Battery Door Replacement: step 9, image 1 of 1
      • Lift open the rubber flap covering the A/V Out port.
      • Remove the 3.4mm screw in the center.
      • During reassembly, put the A/V out rubber door on before replacing the front panel of the camera
      Ask FixBot
    7. Canon PowerShot S50 Front Panel/Battery Door Replacement: step 10, image 1 of 1
      • Use a spudger and gently open up the front panel of the camera.
      • A thin plastic ribbon will stay connected by a brown piece to front panel of the camera.
      Ask FixBot
    8. Canon PowerShot S50 Front Panel/Battery Door Replacement: step 11, image 1 of 1
      • There will be a brown plastic piece keeping the thin plastic ribbon in place.
      • Use the spudger to pull out the brown plastic piece attached to the orange plastic.
      Ask FixBot
    9. Canon PowerShot S50 Front Panel/Battery Door Replacement: step 12, image 1 of 1
      Tool used on this step:
      Buy
      • Use a pair of tweezers and remove the metal piece inside the camera.
      Ask FixBot
    10. Canon PowerShot S50 Front Panel/Battery Door Replacement: step 13, image 1 of 1
      • Remove the battery door
      • NOTE: Putting this back on requires aligning the spring on the back of the door with the hole on the camera
      Ask FixBot
Karim
45 Reputation
3 Guides authored
Cal Poly, Team 7-34, Maness Spring 2012 Member of Cal Poly, Team 7-34, Maness Spring 2012
CPSU-MANESS-S12S7G34
5 Members
71 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 26
Past 30 Days: 104
All Time: 1,998
