Up to 20% off select tools
Canon PowerShot S230 Motherboard Replacement
Views: 2.9K
View statistics:
Past 24 Hours:
2
Past 7 Days:
14
Past 30 Days:
83
All Time:
2,852
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: No estimate
Difficulty: Moderate
Inconsistent Images
Updating the images on this guide to be more consistent with the prerequisites would increase its awesomeness.
Markup Mishap
This guide needs better markups. Help out by correcting or making some markup annotations.
Featured Student Guide
This guide has been the hard work of our awesome students and is found to be exceptionally cool by the iFixit staff.
Tools
  • Phillips #00 Screwdriver
    4.9
  • Spudger
    4.9
Introduction
Go to step 1 ↓
This guide will show you how to remove the motherboard.
    1. Canon PowerShot S230 Motherboard Replacement, Battery: step 1, image 1 of 1
      • On the bottom of the camera, use your thumb to press the rubber battery cover towards the side of the camera with the strap base. The cover will shift to extend beyond the rest of the camera.
      Ask FixBot
    2. Canon PowerShot S230 Motherboard Replacement: step 2, image 1 of 1
      • Hold the end of the battery cover that extends beyond the camera and lift it up.
      Ask FixBot
    3. Canon PowerShot S230 Motherboard Replacement: step 3, image 1 of 1
      • Locate the orange tab next to the battery. Next roll the tab back in order for the battery to come out.
      Ask FixBot
    4. Canon PowerShot S230 Motherboard Replacement: step 4, image 1 of 1
      • Pull the battery out.
      Ask FixBot
    1. Canon PowerShot S230 Motherboard Replacement, Memory Card: step 5, image 1 of 3 Canon PowerShot S230 Motherboard Replacement, Memory Card: step 5, image 2 of 3 Canon PowerShot S230 Motherboard Replacement, Memory Card: step 5, image 3 of 3
      • Locate the sliding button labeled "CF open" on the back of the camera.
      • Press and slide down the button labeled "CF open". The memory card cover will pop open.
      Ask FixBot
    2. Canon PowerShot S230 Motherboard Replacement: step 6, image 1 of 3 Canon PowerShot S230 Motherboard Replacement: step 6, image 2 of 3 Canon PowerShot S230 Motherboard Replacement: step 6, image 3 of 3
      • Push down on the black square button next to the memory card slot. This will release the memory card from the slot.
      Ask FixBot
    3. Canon PowerShot S230 Motherboard Replacement: step 7, image 1 of 2 Canon PowerShot S230 Motherboard Replacement: step 7, image 2 of 2
      • Pull the memory card out of the memory card slot.
      Ask FixBot
    1. Canon PowerShot S230 Motherboard Replacement, Camera Casing: step 8, image 1 of 1
      • Remove two 2.4mm Phillips screws from the right side of the camera.
      Ask FixBot
    2. Canon PowerShot S230 Motherboard Replacement: step 9, image 1 of 1
      • Remove two 2.4mm Phillips screws above the label on the bottom of the camera.
      • Remove two 2.8mm Phillips screws next to the tripod hole.
      Ask FixBot
    3. Canon PowerShot S230 Motherboard Replacement: step 10, image 1 of 1
      • Remove the two 3.2mm Phillips screws that are closer to the top and bottom edges of the camera.
      • Remove the two 3.8mm Phillips screws on either side of the strap base.
      Ask FixBot
    4. Canon PowerShot S230 Motherboard Replacement: step 11, image 1 of 1
      • Remove one 1.6mm Phillips screw from the above the CF open button on back of the camera.
      Ask FixBot
    5. Canon PowerShot S230 Motherboard Replacement: step 12, image 1 of 3 Canon PowerShot S230 Motherboard Replacement: step 12, image 2 of 3 Canon PowerShot S230 Motherboard Replacement: step 12, image 3 of 3
      • Gently pull the front casing from the camera.
      • The following items will either fall off or will be loose: the strap base, the gray rubber cover labeled "Digital A/V Out", and the black rubber piece over the view finder.
      • Remove the memory card cover by sliding down the CF open button and moving the pin.
      Ask FixBot
    6. Canon PowerShot S230 Motherboard Replacement: step 13, image 1 of 2 Canon PowerShot S230 Motherboard Replacement: step 13, image 2 of 2
      • Gently pull the back casing from the camera.
      Ask FixBot
    1. Canon PowerShot S230 Motherboard Replacement, Buttons: step 14, image 1 of 2 Canon PowerShot S230 Motherboard Replacement, Buttons: step 14, image 2 of 2
      • Locate the reverse side of the buttons by looking at the inside of the back camera casing.
      • Locate the button sensors, which connect to the logic board by a connecting ribbon, by looking at the back of the camera once the back casing has been removed.
      • The button sensors on the back of the camera should appear to match up with the reverse side of the buttons on the inside of the back camera casing. Imagine one as being the reverse image, or mirror image, of the other. This will help you locate where a problem is occuring if a button or a button sensor has been damaged.
      Ask FixBot
    2. Canon PowerShot S230 Motherboard Replacement: step 15, image 1 of 1
      • Remove one 4.3mm screw directly below the power button on the top of the camera.
      • This screw attaches the entire panel for the power and picture-taking buttons. Be sure you are removing the screw from the top of the camera, as it is close to another screw on the back side of the camera.
      Ask FixBot
    3. Canon PowerShot S230 Motherboard Replacement: step 16, image 1 of 2 Canon PowerShot S230 Motherboard Replacement: step 16, image 2 of 2
      • Gently lift the button panel from the top of the camera.
      • This is what the reverse side of the button panel looks like after removal.
      Ask FixBot
    1. Canon PowerShot S230 Motherboard Replacement, Motherboard: step 17, image 1 of 1
      • Remove the two 3.9mm screws holding down the copper flap that insulates the motherboard.
      Ask FixBot
    2. Canon PowerShot S230 Motherboard Replacement: step 18, image 1 of 3 Canon PowerShot S230 Motherboard Replacement: step 18, image 2 of 3 Canon PowerShot S230 Motherboard Replacement: step 18, image 3 of 3
      • The motherboard can be damaged easily and must be treated with care. Try to avoid removing ribbon cables with your fingers, since motherboards are extremely sensitive to static discharge. Use a spudger or plastic opening tool to lift any flaps or tabs or to pry connectors straight off their sockets on the motherboard.
      • Before the motherboard can be removed, several ribbon cables must be disconnected from their respective ports. A few of the ribbon cables are held in place by locking ZIF connectors, which you must release before removing the cables. Removing each ribbon cable may require a gentle tug.
      • First, release the ZIF connector securing the ribbon cable in the bottom left corner of the motherboard. To do this, insert the flat end of a spudger under the connector's dark brown flap and gently wedge the flap open.
      Ask FixBot
    3. Canon PowerShot S230 Motherboard Replacement: step 19, image 1 of 2 Canon PowerShot S230 Motherboard Replacement: step 19, image 2 of 2
      • Now, insert the spudger under the ribbon cable and gently pull the cable out of its port.
      Ask FixBot
    4. Canon PowerShot S230 Motherboard Replacement: step 20, image 1 of 3 Canon PowerShot S230 Motherboard Replacement: step 20, image 2 of 3 Canon PowerShot S230 Motherboard Replacement: step 20, image 3 of 3
      • Release the ZIF connector securing the next ribbon cable. To do this, insert the flat end of a spudger between the dark brown piece and the white piece of the connector. Since the dark brown piece is under the ribbon cable, move this piece to the right by wedging one end at a time.
      Ask FixBot
    5. Canon PowerShot S230 Motherboard Replacement: step 21, image 1 of 2 Canon PowerShot S230 Motherboard Replacement: step 21, image 2 of 2
      • Insert the spudger under the ribbon cable and gently pull the cable out of its port.
      Ask FixBot
    6. Canon PowerShot S230 Motherboard Replacement: step 22, image 1 of 3 Canon PowerShot S230 Motherboard Replacement: step 22, image 2 of 3 Canon PowerShot S230 Motherboard Replacement: step 22, image 3 of 3
      • Release the ZIF connector securing the ribbon directly below the lens. To do this, insert the pointed end of the spudger between the black piece of the connector and the white piece. Wedge the black piece down.
      Ask FixBot
    7. Canon PowerShot S230 Motherboard Replacement: step 23, image 1 of 2 Canon PowerShot S230 Motherboard Replacement: step 23, image 2 of 2
      • Insert the pointed end of the spudger under the ribbon cable and gently pull the cable out of its port.
      Ask FixBot
    8. Canon PowerShot S230 Motherboard Replacement: step 24, image 1 of 2 Canon PowerShot S230 Motherboard Replacement: step 24, image 2 of 2
      • The rest of the ribbon cables are not secured with ZIF connectors. Remove the ribbon cable on the bottom right corner of the motherboard by using the flat end of the spudger to pry the cable from the board.
      Ask FixBot
    9. Canon PowerShot S230 Motherboard Replacement: step 25, image 1 of 2 Canon PowerShot S230 Motherboard Replacement: step 25, image 2 of 2
      • Remove the ribbon cable on the top left corner of the motherboard by using the flat end of the spudger to pry the cable from the board.
      Ask FixBot
    10. Canon PowerShot S230 Motherboard Replacement: step 26, image 1 of 2 Canon PowerShot S230 Motherboard Replacement: step 26, image 2 of 2
      • Remove the next ribbon cable by using the flat end of the spudger to pry the cable from the board.
      Ask FixBot
    11. Canon PowerShot S230 Motherboard Replacement: step 27, image 1 of 2 Canon PowerShot S230 Motherboard Replacement: step 27, image 2 of 2
      • Remove the last ribbon cable by using the flat end of the spudger to pry the cable from the board.
      • When replacing the ribbon cables, keep in mind that these last four cables simply snap back onto the motherboard.
      Ask FixBot
    12. Canon PowerShot S230 Motherboard Replacement: step 28, image 1 of 3 Canon PowerShot S230 Motherboard Replacement: step 28, image 2 of 3 Canon PowerShot S230 Motherboard Replacement: step 28, image 3 of 3
      • Remove one 3.9mm screw from the right side of the motherboard and under the flash.
      • The ends of the connecting ribbons may get caught on the motherboard as you remove it from the camera.
      • Gently pull the motherboard away from the front of the camera.
      Ask FixBot
Author
with
Tanya Malalang
340 Reputation
3 Guides authored
Cal Poly, Team 13-1, Forte Winter 2011 Member of Cal Poly, Team 13-1, Forte Winter 2011
CPSU-FORTE-W11S13G1
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 14
Past 30 Days: 83
All Time: 2,852
