Inconsistent Images
Updating the images on this guide to be more consistent with the prerequisites would increase its awesomeness.
Markup Mishap
This guide needs better markups. Help out by correcting or making some markup annotations.
Tools
Introduction
Go to step 1 ↓This guide will show you how to get to the buttons to view them from inside the casing and to view the button sensors that are attached to the logic board.
On the bottom of the camera, use your thumb to press the rubber battery cover towards the side of the camera with the strap base. The cover will shift to extend beyond the rest of the camera.
Locate the sliding button labeled "CF open" on the back of the camera.
Press and slide down the button labeled "CF open". The memory card cover will pop open.
Locate the reverse side of the buttons by looking at the inside of the back camera casing.
Locate the button sensors, which connect to the logic board by a connecting ribbon, by looking at the back of the camera once the back casing has been removed.
