Up to 20% off select tools
Canon PowerShot S110 Display Replacement
Views: 5.1K
View statistics:
Past 24 Hours:
5
Past 7 Days:
22
Past 30 Days:
132
All Time:
5,146
Comments: 13
3 comments on steps, 10 guide comments.
Go to guide comments
Completed: 4
4 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 - 10 minutes
Difficulty: Moderate
Tools
  • Phillips #0 Screwdriver
    5
  • Spudger
    4.9
Introduction
Go to step 1 ↓
This is a step by step guide that demonstrates how to replace the display for your Canon PowerShot S110.
    1. Canon PowerShot S110 Display  Replacement, Display: step 1, image 1 of 2 Canon PowerShot S110 Display  Replacement, Display: step 1, image 2 of 2
      • Slide open the battery cover on the bottom of the camera.
      • Eject the battery by pulling the red release latch.
      • Battery must be removed to avoid shorting any part of the camera
      Ask FixBot
    2. Canon PowerShot S110 Display  Replacement: step 2, image 1 of 3 Canon PowerShot S110 Display  Replacement: step 2, image 2 of 3 Canon PowerShot S110 Display  Replacement: step 2, image 3 of 3
      • Use a #0 Phillips screwdriver to remove the following screws:
      • the 2 screws on the side of the camera near the HDMI input panel,
      • the 2 screws on the opposite side of the camera,
      • and the 2 screws on the bottom of the camera near the tripod mounting hole.
      Ask FixBot
    3. Canon PowerShot S110 Display  Replacement: step 3, image 1 of 1
      • Once the screws are removed, use a spudger to carefully detach the cover.
      Ask FixBot
    4. Canon PowerShot S110 Display  Replacement: step 4, image 1 of 2 Canon PowerShot S110 Display  Replacement: step 4, image 2 of 2
      • Before we are able to remove the display, we must take off the mounting bracket that holds it in place.
      • Remove the single screw indicated in red.
      • Detach the bracket and set it aside.
      • In preparation for the next step, remove the screw indicated in yellow.
      Ask FixBot
    5. Canon PowerShot S110 Display  Replacement: step 5, image 1 of 3 Canon PowerShot S110 Display  Replacement: step 5, image 2 of 3 Canon PowerShot S110 Display  Replacement: step 5, image 3 of 3
      • To detach the first logic ribbon:
      • Use a small, relatively soft pointed tool to slowly pull out the ribbon using the hole shown in the image.
      • Completely remove the ribbon.
      • The display is now partially disconnected from the back side of the camera.
      Ask FixBot
    6. Canon PowerShot S110 Display  Replacement: step 6, image 1 of 3 Canon PowerShot S110 Display  Replacement: step 6, image 2 of 3 Canon PowerShot S110 Display  Replacement: step 6, image 3 of 3
      • To remove the front camera case in order to access the remaining ribbons:
      • Slowly pry around the edges using a spudger.
      • A circular ring pad will detach. Set this aside.
      • You now have access to the logic ribbons on the front of the camera.
      Ask FixBot
    7. Canon PowerShot S110 Display  Replacement: step 7, image 1 of 3 Canon PowerShot S110 Display  Replacement: step 7, image 2 of 3 Canon PowerShot S110 Display  Replacement: step 7, image 3 of 3
      • Using the spudger, flip the small tab that is holding down the logic ribbon located at the top left corner.
      • Flip the larger tab that is holding down the logic ribbon located directly to the right of the previous ribbon.
      • Detach both ribbons from the circuit board.
      Ask FixBot
    8. Canon PowerShot S110 Display  Replacement: step 8, image 1 of 3 Canon PowerShot S110 Display  Replacement: step 8, image 2 of 3 Canon PowerShot S110 Display  Replacement: step 8, image 3 of 3
      • Flip the tab and remove the last ribbon.
      • This ribbon is revealed after Step 7.
      • The display can now be lifted off the camera and the logic ribbons attached in the front can slide out.
      • Prepare your replacement display and move on to reassembly.
      Ask FixBot
Reassembly
4 other people completed this guide.
Author
with
akac92
319 Reputation
2 Guides authored
UW Tacoma, Team 1-2, Liner SU 2015 Member of UW Tacoma, Team 1-2, Liner SU 2015
UWT-LINER-SU15S1G2
4 Members
36 Guides authored
10 Guide Comments
Oh My God, it works!!! Thanks for the great instructions, very clear and easy.
Thank you!!!
robertmadsen2000 - Reply Share
Caution, the re-assembly is much more challenging than the dear-down. Masking tape (to temporarily hold the screen and func. set dial assembly in place while attaching the ribbon cables), tooth picks (the ends fit nicely in the ribbon cable holes) and a small plastic putty knife (for raising cable hold-downs) nay come in handy. You will find that the camera face has a ribbon cable for the control ring. When reassembling, note that there are anchor nobs over which holes in the cables go - front side of camera. Reinserting the func set cable under the control ring after attaching the screen cables is difficult (tight fit). Try inserting tooth picks to make room. My new screen cost $30 from D H Cameras on eBay.
Dennis - Reply Share
To reassembly your device:
http://culturillainformatica.blogspot.co...
Spanish, ;-)
Jaibca - Reply Share
Past 24 Hours: 5
Past 7 Days: 22
Past 30 Days: 132
All Time: 5,146
