Canon PowerShot S100 Top Panel Replacement
    1. Canon PowerShot S100 Top Panel Replacement, Outer Case: step 1, image 1 of 3 Canon PowerShot S100 Top Panel Replacement, Outer Case: step 1, image 2 of 3 Canon PowerShot S100 Top Panel Replacement, Outer Case: step 1, image 3 of 3
      • Remove the 2 screws (3.2mm, Phillips #00) found on the bottom side of the camera.
      • Remove the 2 screws (3.2mm, Phillips #00) found on the side of the camera.
      • Remove the 2 screws (3.2mm, Phillips #00) found on the side of the camera where the terminals are.
      • Open the flap revealing the cable inputs and remove the final screw (3.8mm, Phillips #00) found inside.
      Ask FixBot
    2. Canon PowerShot S100 Top Panel Replacement: step 2, image 1 of 1
      • Turn the camera so that the LCD screen is facing you.
      • Remove the back panel by pulling it off of the camera.
      Ask FixBot
    3. Canon PowerShot S100 Top Panel Replacement: step 3, image 1 of 3 Canon PowerShot S100 Top Panel Replacement: step 3, image 2 of 3 Canon PowerShot S100 Top Panel Replacement: step 3, image 3 of 3
      Tool used on this step:
      Buy
      • Turn the camera so that the lens is facing you.
      • Do not pull the front panel off without removing the ribbon cable first.
      • Slowly lift the front panel from the camera.
      • The ribbon cable is connecting the front panel to the camera. Using the tweezers, gently pull the ribbon cable out of its socket.
      • A spudger may also be used to remove the ribbon cable.
      • Remove the rubber guard that rests on top of the lens.
      Ask FixBot
    1. Canon PowerShot S100 Top Panel Replacement, Top Panel: step 4, image 1 of 1
      • Turn the camera over on its side so that the terminals are facing you.
      • Remove the screw (3.9mm, Phillips #00) that is connecting the top panel to the metal frame.
      Ask FixBot
    2. Canon PowerShot S100 Top Panel Replacement: step 5, image 1 of 2 Canon PowerShot S100 Top Panel Replacement: step 5, image 2 of 2
      • Remove the screw (2.9mm, Phillips #00) that is directly above the camera lens.
      Ask FixBot
    3. Canon PowerShot S100 Top Panel Replacement: step 6, image 1 of 2 Canon PowerShot S100 Top Panel Replacement: step 6, image 2 of 2
      Buy
      • Using the spudger, remove the center ribbon cable that is connecting the top panel to the motherboard.
      • Gently lift the top panel off the camera.
      • Tweezers may also be used to remove the ribbon cable.
      Ask FixBot
3 other people completed this guide.
Ricky
975 Reputation
5 Guides authored
USF Tampa, Team 1-4, Leahy Winter 2015 Member of USF Tampa, Team 1-4, Leahy Winter 2015
USFT-LEAHY-W15S1G4
4 Members
60 Guides authored
1 Guide Comment
Ricky hi please I need some help! I repaired the screen but now the flash will not turn on! When I press the button the flash on the screen still says it is not on, and the flash itself will not pop out! What do I do!
Emily - Reply Share
Past 24 Hours: 1
Past 7 Days: 15
Past 30 Days: 60
All Time: 2,947
