Canon PowerShot S100 Control Dial Assembly Replacement
Views: 2K
View statistics:
Past 24 Hours:
Past 7 Days:
15
Past 30 Days:
96
All Time:
1,965
Comments: 2
1 comment on steps, 1 guide comment.
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 10 - 15 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
The control dial on the back of the camera can be removed and replaced.The control dial is used to adjust the camera's settings and navigate the camera menus.
Tools
    1. Canon PowerShot S100 Control Dial Assembly Replacement, Outer Case: step 1, image 1 of 3 Canon PowerShot S100 Control Dial Assembly Replacement, Outer Case: step 1, image 2 of 3 Canon PowerShot S100 Control Dial Assembly Replacement, Outer Case: step 1, image 3 of 3
      • Remove the 2 screws (3.2mm, Phillips #00) found on the bottom side of the camera.
      • Remove the 2 screws (3.2mm, Phillips #00) found on the side of the camera.
      • Remove the 2 screws (3.2mm, Phillips #00) found on the side of the camera where the terminals are.
      • Open the flap revealing the cable inputs and remove the final screw (3.8mm, Phillips #00) found inside.
      Ask FixBot
    2. Canon PowerShot S100 Control Dial Assembly Replacement: step 2, image 1 of 1
      • Turn the camera so that the LCD screen is facing you.
      • Remove the back panel by pulling it off of the camera.
      Ask FixBot
    3. Canon PowerShot S100 Control Dial Assembly Replacement: step 3, image 1 of 3 Canon PowerShot S100 Control Dial Assembly Replacement: step 3, image 2 of 3 Canon PowerShot S100 Control Dial Assembly Replacement: step 3, image 3 of 3
      Tool used on this step:
      Buy
      • Turn the camera so that the lens is facing you.
      • Do not pull the front panel off without removing the ribbon cable first.
      • Slowly lift the front panel from the camera.
      • The ribbon cable is connecting the front panel to the camera. Using the tweezers, gently pull the ribbon cable out of its socket.
      • A spudger may also be used to remove the ribbon cable.
      • Remove the rubber guard that rests on top of the lens.
      Ask FixBot
    1. Canon PowerShot S100 Control Dial Assembly Replacement, Control Dial Assembly: step 4, image 1 of 1
      • Turn the camera over so that the LCD screen is facing you.
      • Remove the screw (3.9mm, Phillips #00) that is attaching the thin metal frame to the camera.
      • Remove the 2 screws (3.1mm, Phillips #00) that are attaching the control dial panel to the camera.
      Ask FixBot
    2. Canon PowerShot S100 Control Dial Assembly Replacement: step 5, image 1 of 1
      Buy
      • Using the tweezers, detach the ribbon cable that is connected to the dial panel.
      Ask FixBot
    3. Canon PowerShot S100 Control Dial Assembly Replacement: step 6, image 1 of 2 Canon PowerShot S100 Control Dial Assembly Replacement: step 6, image 2 of 2
      • Turn the camera over so that the lens is facing you.
      • Using the tweezers, gently lift the flap that is securing the ribbon cable to the motherboard.
      • Using the tweezers, remove the ribbon cable from its socket.
      Ask FixBot
    4. Canon PowerShot S100 Control Dial Assembly Replacement: step 7, image 1 of 1
      • Gently pull the control dial panel, and its attached ribbon cable, through the opening between the top panel and the camera body.
      Ask FixBot
Ricky
975 Reputation
5 Guides authored
USF Tampa, Team 1-4, Leahy Winter 2015 Member of USF Tampa, Team 1-4, Leahy Winter 2015
USFT-LEAHY-W15S1G4
4 Members
60 Guides authored
1 Guide Comment
I have Canon S100 and it was stuck. Can I send this camera to you to get it fixed and if so, what is your address and how much it will cost?
Yeluchuri Paparao - Reply Share
Past 24 Hours: 1
Past 7 Days: 15
Past 30 Days: 96
All Time: 1,965
