Canon PowerShot G7X Lens Replacement
    1. Canon PowerShot G7X Lens Replacement, Dial: step 1, image 1 of 1
      • Remove the five 2mm Phillips #000 screws that are under the screen of the camera.
      Ask FixBot
    2. Canon PowerShot G7X Lens Replacement: step 2, image 1 of 1
      • Remove the two 3mm Phillips #000 screws under the AV-out digital flap.
      • Remove the two 3 mm Phillips #000 screws from the side of the camera.
      Ask FixBot
    3. Canon PowerShot G7X Lens Replacement: step 3, image 1 of 1
      • Remove the two 3 mm Phillips #000 screws on the side of camera with the flash toggle.
      Ask FixBot
    4. Canon PowerShot G7X Lens Replacement: step 4, image 1 of 1
      • Remove the four 4 mm Phillips #000 screws from the plate on the bottom of the camera.
      Ask FixBot
    5. Canon PowerShot G7X Lens Replacement: step 5, image 1 of 1
      • Remove the back plate.
      Ask FixBot
    6. Canon PowerShot G7X Lens Replacement: step 6, image 1 of 1
      • Remove the three 3 mm Phillips #000 screws around the dial.
      Ask FixBot
    7. Canon PowerShot G7X Lens Replacement: step 7, image 1 of 2 Canon PowerShot G7X Lens Replacement: step 7, image 2 of 2
      • Using the nylon spudger, gently lift the ZIF tab.
      • Disconnect the ribbon cable that connects the dial to the motherboard.
      • Remove the dial from the device.
      Ask FixBot
    1. Canon PowerShot G7X Lens Replacement, Flash: step 8, image 1 of 2 Canon PowerShot G7X Lens Replacement, Flash: step 8, image 2 of 2
      • Remove the three, blue 5 mm Phillips screws from the back plate.
      • Remove seven 2 mm Phillips #000 screws.
      Ask FixBot
    2. Canon PowerShot G7X Lens Replacement: step 9, image 1 of 2 Canon PowerShot G7X Lens Replacement: step 9, image 2 of 2
      • While using the plastic opening tool, gently pry the top plate off the camera.
      Ask FixBot
    3. Canon PowerShot G7X Lens Replacement: step 10, image 1 of 2 Canon PowerShot G7X Lens Replacement: step 10, image 2 of 2
      • Using the black nylon spudger, gently lift the ribbon cable connected to the LCD screen housing until it comes out then remove the housing.
      Ask FixBot
    4. Canon PowerShot G7X Lens Replacement: step 11, image 1 of 2 Canon PowerShot G7X Lens Replacement: step 11, image 2 of 2
      • Remove the 2 mm Phillips #000 screw underneath the top plate.
      • Remove silver plate.
      Ask FixBot
    5. Canon PowerShot G7X Lens Replacement: step 12, image 1 of 1
      • Take the Phillips #000 and remove the three 5 mm screws from the front plate.
      Ask FixBot
    6. Canon PowerShot G7X Lens Replacement: step 13, image 1 of 2 Canon PowerShot G7X Lens Replacement: step 13, image 2 of 2
      • Using the spudger, gently lift the ribbon cable from underneath the front plate.
      • Remove the front plate.
      Ask FixBot
    7. Canon PowerShot G7X Lens Replacement: step 14, image 1 of 2 Canon PowerShot G7X Lens Replacement: step 14, image 2 of 2
      • Remove flash toggle plate.
      • Remove the 2mm Phillips #000 screws under the flash toggle.
      Ask FixBot
    8. Canon PowerShot G7X Lens Replacement: step 15, image 1 of 2 Canon PowerShot G7X Lens Replacement: step 15, image 2 of 2
      • Flash contains charged capacitor. Shock hazard.
      • Using the black nylon spudger, gently lift the ribbon cable that connects the flash to motherboard and remove the flash from the device.
      Ask FixBot
    1. Canon PowerShot G7X Lens Replacement, Lens: step 16, image 1 of 1
      • Remove the 5 mm Phillips #000 screw from the copper plate.
      Ask FixBot
    2. Canon PowerShot G7X Lens Replacement: step 17, image 1 of 1
      • Using the black nylon spudger, lift the ribbon cable gently until it comes out.
      Ask FixBot
    3. Canon PowerShot G7X Lens Replacement: step 18, image 1 of 1
      • Remove the copper plate to reveal connections to the lens.
      Ask FixBot
    4. Canon PowerShot G7X Lens Replacement: step 19, image 1 of 1
      • Using the black nylon spudger, lift gently on the pin connector until it comes off.
      Ask FixBot
    5. Canon PowerShot G7X Lens Replacement: step 20, image 1 of 2 Canon PowerShot G7X Lens Replacement: step 20, image 2 of 2
      • Using the spudger, gently lift on the ribbon cable until it comes out.
      • Separate the lens from the motherboard.
      Ask FixBot
2 other people completed this guide.
3 Guide Comments
Not that great of step by step. Lots of missed steps and lots different screw length and thread. Over all it's just an ok guide.
Nick Thomas - Reply Share
how do you tell if the lens is CCD or not
kingwayne77none - Reply Share
Poor instructions indeed. At step 11 silver plate still stuck. More screws than indicated.
Hugo Lyppens - Reply Share
Past 24 Hours: 2
Past 7 Days: 35
Past 30 Days: 140
All Time: 9,290
