Canon PowerShot G7X Dial Replacement
    1. Canon PowerShot G7X Dial Replacement, Dial: step 1, image 1 of 1
      • Remove the five 2mm Phillips #000 screws that are under the screen of the camera.
      Ask FixBot
    2. Canon PowerShot G7X Dial Replacement: step 2, image 1 of 1
      • Remove the two 3mm Phillips #000 screws under the AV-out digital flap.
      • Remove the two 3 mm Phillips #000 screws from the side of the camera.
      Ask FixBot
    3. Canon PowerShot G7X Dial Replacement: step 3, image 1 of 1
      • Remove the two 3 mm Phillips #000 screws on the side of camera with the flash toggle.
      Ask FixBot
    4. Canon PowerShot G7X Dial Replacement: step 4, image 1 of 1
      • Remove the four 4 mm Phillips #000 screws from the plate on the bottom of the camera.
      Ask FixBot
    5. Canon PowerShot G7X Dial Replacement: step 5, image 1 of 1
      • Remove the back plate.
      Ask FixBot
    6. Canon PowerShot G7X Dial Replacement: step 6, image 1 of 1
      • Remove the three 3 mm Phillips #000 screws around the dial.
      Ask FixBot
    7. Canon PowerShot G7X Dial Replacement: step 7, image 1 of 2 Canon PowerShot G7X Dial Replacement: step 7, image 2 of 2
      • Using the nylon spudger, gently lift the ZIF tab.
      • Disconnect the ribbon cable that connects the dial to the motherboard.
      • Remove the dial from the device.
      Ask FixBot
1 Guide Comment
Good guide. If you need to repair the jog dial, check this video for an excellent guide: https://www.youtube.com/watch?v=amuCb5ko...
jnbruin - Reply Share
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 32
All Time: 914
