Up to 20% off select tools
Canon PowerShot G16 Battery Replacement
Views: 1.9K
View statistics:
Past 24 Hours:
4
Past 7 Days:
19
Past 30 Days:
94
All Time:
1,894
Comments: 2
1 comment on steps, 1 guide comment.
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 35 seconds
Difficulty: Very easy
Introduction
Go to step 1 ↓
Please follow these simple steps to replace your battery. Perform this procedure if you have a replacement battery or intend to charge your battery outside of the camera.
    1. Canon PowerShot G16  Battery Replacement, Battery: step 1, image 1 of 3 Canon PowerShot G16  Battery Replacement, Battery: step 1, image 2 of 3 Canon PowerShot G16  Battery Replacement, Battery: step 1, image 3 of 3
      • Open the battery flap on the bottom of the camera by applying pressure and pushing in the direction of the arrow.
      • Remove your finger and allow the flap to pop open.
      Ask FixBot
    2. Canon PowerShot G16  Battery Replacement: step 2, image 1 of 3 Canon PowerShot G16  Battery Replacement: step 2, image 2 of 3 Canon PowerShot G16  Battery Replacement: step 2, image 3 of 3
      • Push the brown lever so that it pivots counterclockwise.
      • Grip and remove the battery.
      Ask FixBot
Author
with
Jonathan Harger
1,270 Reputation
5 Guides authored
Cal Poly, Team 70-6, Forte Winter 2016 Member of Cal Poly, Team 70-6, Forte Winter 2016
CPSU-FORTE-W16S70G6
4 Members
72 Guides authored
1 Guide Comment
Hello Sr may be you can add something more ..I have this unit, really not using much ,After 6 month no charged I tried to used iven with new battery not start at all
thank you
Michele Fiscaletti - Reply Share
Past 24 Hours: 4
Past 7 Days: 19
Past 30 Days: 94
All Time: 1,894
