Canon PowerShot G12 LCD Screen Replacement
Views: 10K
View statistics:
Past 24 Hours:
10
Past 7 Days:
44
Past 30 Days:
217
All Time:
10,388
Comments: 3
1 comment on steps, 2 guide comments.
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 3
3 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 20 - 30 minutes
Difficulty: Difficult
Introduction
Go to step 1 ↓
Replacing the LCD screen is a highly-invasive, step-intensive process that becomes necessary if the screen has sustained damage to due a crack, water, or an otherwise internal malfunction.
In this guide, you will learn how to replace the LCD screen carefully.
Parts
Tools
    1. Canon PowerShot G12 LCD Screen Replacement, LCD Screen: step 1, image 1 of 1
      • Open the LCD screen from its locked position so the screen is visible.
      Ask FixBot
    2. Canon PowerShot G12 LCD Screen Replacement: step 2, image 1 of 1
      • Flip the LCD screen perpendicular to the camera exposing the side screws.
      • Using a Phillips-head 00 screwdriver, unscrew the screws on both sides of the LCD screen.
      Ask FixBot
    3. Canon PowerShot G12 LCD Screen Replacement: step 3, image 1 of 1
      • Remove the front plate which states the Canon brand by prying open the side farthest from the camera simply with your fingers.
      • The circuit and internal wires will be exposed.
      Ask FixBot
    4. Canon PowerShot G12 LCD Screen Replacement: step 4, image 1 of 1
      • Flip the LCD screen vertically and remove the final screws on the outer edge of the screen with the same Phillips-head 00 screwdriver. All screws have Loctite (blue) on them so they a difficult to turn. Make sure your Phillips screw driver fits perfectly. Sometimes a new screwdriver will need to have the tip filed down a little to fit.
      • The internal mechanisms will become loose and be able to be taken out.
      Ask FixBot
    5. Canon PowerShot G12 LCD Screen Replacement: step 5, image 1 of 1
      • Using a spudger, remove the external shell of the LCD screen leaving only the metal internal circuit board and screen attached.
      Ask FixBot
    6. Canon PowerShot G12 LCD Screen Replacement: step 6, image 1 of 1
      Tool used on this step:
      Buy
      • Using a pair of precision tweezers, carefully remove the yellow circuit connector from the port on the green circuit board.
      • Pull the yellow circuit connector down removing the screen from the metal shell.
      Ask FixBot
    7. Canon PowerShot G12 LCD Screen Replacement: step 7, image 1 of 1
      • Place the new LCD screen into the metal shell with the yellow connector tab facing outward.
      • Connect the new screen with the green circuit board ensuring you use the tweezers to connect it fully into the port.
      Ask FixBot
3 other people completed this guide.
Nathan Meuwissen
576 Reputation
3 Guides authored
USF Tampa, Team 1-5, Leahy Winter 2015 Member of USF Tampa, Team 1-5, Leahy Winter 2015
USFT-LEAHY-W15S1G5
3 Members
60 Guides authored
2 Guide Comments
ATTENTION
Connector of cable between camera and lcd board can be fit up or down side
Mark it before disconnect
Dufour - Reply Share
Hello!
I wanted to change the screen but it seems that camera screen differ from each other according to the country where you bought it has anyone any piece of advice ?
I bought it in Singapore but live in Europe and I’m afraid to waist money buying a European one!
Chloe a - Reply Share
Past 24 Hours: 10
Past 7 Days: 44
Past 30 Days: 217
All Time: 10,388
