Canon PowerShot G1 X Battery Replacement
Views: 1.1K
View statistics:
Past 24 Hours:
Past 7 Days:
21
Past 30 Days:
85
All Time:
1,078
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 1 minute
Difficulty: Easy
Introduction
Go to step 1 ↓
Does your camera not power on or hold a charge? You may have a faulty battery that needs replacing.
    1. Canon PowerShot G1 X Battery Replacement, Battery: step 1, image 1 of 1
      • Pull the switch on the back of the battery case back towards the open arrow to release a latch.
      • The lid should pop open revealing the battery and a small red switch holding the battery in place.
      Ask FixBot
    2. Canon PowerShot G1 X Battery Replacement: step 2, image 1 of 2 Canon PowerShot G1 X Battery Replacement: step 2, image 2 of 2
      • To release the battery, gently push the switch off the top of the battery and pull the battery out of the casing.
      • Place the new battery in the casing with the four metal connections (small squares on the bottom of the battery)in the bottom right hand corner of the bottom of the camera. If you look inside the casing you will see where the connections will meet. This will give you more of an idea on the orientation of the battery.
      Ask FixBot
Cleston Sanders
124 Reputation
1 Guide authored
USF Tampa, Team 20-1, Remmell Spring 2017 Member of USF Tampa, Team 20-1, Remmell Spring 2017
USFT-REMMELL-S17S20G1
3 Members
48 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 21
Past 30 Days: 85
All Time: 1,078
