Canon PowerShot ELPH330 HS Camera Power/Shutter Button Panel Replacement
View statistics:
Past 24 Hours:
0
Past 7 Days:
14
Past 30 Days:
59
All Time:
842
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 10 - 20 minutes
Difficulty: Moderate
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Introduction
Go to step 1 ↓
If you’re experiencing problems with your camera turning on or the camera taking photos, consider replacing the power/shutter button panel on your Canon PowerShot ELPH330 HS camera. This guide will show you how to replace your damaged power button.
Before you begin, make sure that your camera is turned off and you remove the battery.
Tools
    1. Canon PowerShot ELPH330 HS Camera Power/Shutter Button Panel Replacement, Power/Shutter Button Panel: step 1, image 1 of 2 Canon PowerShot ELPH330 HS Camera Power/Shutter Button Panel Replacement, Power/Shutter Button Panel: step 1, image 2 of 2
      • On the top-center of your device, turn off the camera by pressing the power button.
      • Put your finger on the battery door and slide the battery door to the right to open it.
      • Push the release button downward and it will release the battery.
      Ask FixBot
    2. Canon PowerShot ELPH330 HS Camera Power/Shutter Button Panel Replacement: step 2, image 1 of 1
      • Use the Phillips #00 screwdriver to remove the screws.
      Ask FixBot
    3. Canon PowerShot ELPH330 HS Camera Power/Shutter Button Panel Replacement: step 3, image 1 of 1
      • Remove the two 4.0mm screws on the bottom of the camera located near the battery door using a Phillips #00 screwdriver.
      Ask FixBot
    4. Canon PowerShot ELPH330 HS Camera Power/Shutter Button Panel Replacement: step 4, image 1 of 1
      • At the bottom of the camera next to the battery door, remove two more screws using the Phillips #00 screwdriver.
      Ask FixBot
    5. Canon PowerShot ELPH330 HS Camera Power/Shutter Button Panel Replacement: step 5, image 1 of 1
      • To remove the back portion of the camera case, use your fingers to carefully pry the case apart at the seam.
      Ask FixBot
    6. Canon PowerShot ELPH330 HS Camera Power/Shutter Button Panel Replacement: step 6, image 1 of 2 Canon PowerShot ELPH330 HS Camera Power/Shutter Button Panel Replacement: step 6, image 2 of 2
      • On the motherboard there should be a white port. Using the spudger, disconnect it from the motherboard.
      Ask FixBot
    7. Canon PowerShot ELPH330 HS Camera Power/Shutter Button Panel Replacement: step 7, image 1 of 1
      • Follow the green and white wire. There is a gray piece of rubber holding the button into place. Remove it with the spudger.
      Ask FixBot
    8. Canon PowerShot ELPH330 HS Camera Power/Shutter Button Panel Replacement: step 8, image 1 of 1
      • Lift the panel off from the top of the camera with your hands.
      Ask FixBot
Michelle Ngo
595 Reputation
3 Guides authored
UW Tacoma, Team S1-G3, Liner Summer 2019 Member of UW Tacoma, Team S1-G3, Liner Summer 2019
UWT-LINER-SU19S1G3
4 Members
36 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 14
Past 30 Days: 59
All Time: 842
