Canon PowerShot ELPH330 HS Camera Case Replacement
    1. Canon PowerShot ELPH330 HS Camera Case Replacement, Camera Case: step 1, image 1 of 2 Canon PowerShot ELPH330 HS Camera Case Replacement, Camera Case: step 1, image 2 of 2
      • On the top-center of your device, turn off the camera by pressing the power button.
      • Put your finger on the battery door and slide the battery door to the right which will then open the door.
      • Push the release button downward and it will release the battery.
      Ask FixBot
    2. Canon PowerShot ELPH330 HS Camera Case Replacement: step 2, image 1 of 1
      • Use the Phillips #00 screwdriver to remove the two screws.
      Ask FixBot
    3. Canon PowerShot ELPH330 HS Camera Case Replacement: step 3, image 1 of 1
      • Remove two more screws using the Phillips #00 screwdriver.
      Ask FixBot
    4. Canon PowerShot ELPH330 HS Camera Case Replacement: step 4, image 1 of 1
      • On the lower right side of the camera case, remove the single screw using Phillips #00 screwdriver.
      • On the upper right side of the camera, remove the HDMI A/V out port.
      • Beneath the port cover, remove the screw using the same Phillips #00 screwdriver.
      Ask FixBot
    5. Canon PowerShot ELPH330 HS Camera Case Replacement: step 5, image 1 of 1
      • Using your fingers, carefully pry the case apart at the seam.
      Ask FixBot
Michelle Ngo
595 Reputation
3 Guides authored
UW Tacoma, Team S1-G3, Liner Summer 2019 Member of UW Tacoma, Team S1-G3, Liner Summer 2019
UWT-LINER-SU19S1G3
4 Members
36 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 25
All Time: 613
