Canon PowerShot ELPH330 HS Camera Repair LCD Screen Replacement
Views: 1.2K
View statistics:
Past 24 Hours:
0
Past 7 Days:
20
Past 30 Days:
66
All Time:
1,240
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 8 minutes
Difficulty: Moderate
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Introduction
Go to step 1 ↓
If you’re experiencing problems with your screen, consider reading this guide. This guide will show you how to replace the LCD screen in your Canon PowerShot ELPH 330 HS.
Tools
    1. Canon PowerShot ELPH330 HS Camera  Repair LCD Screen  Replacement, LCD Screen: step 1, image 1 of 2 Canon PowerShot ELPH330 HS Camera  Repair LCD Screen  Replacement, LCD Screen: step 1, image 2 of 2
      • Turn off your camera.
      • Remove the battery.
      • Slide the battery door open with the rubber pad on the bottom right side of the camera.
      • Remove the battery by pushing down on the release button.
      Ask FixBot
    2. Canon PowerShot ELPH330 HS Camera  Repair LCD Screen  Replacement: step 2, image 1 of 1
      • Remove the two screws on the left side with a Phillips #00 screwdriver.
      Ask FixBot
    3. Canon PowerShot ELPH330 HS Camera  Repair LCD Screen  Replacement: step 3, image 1 of 1
      • Remove the two screws on the bottom of the camera with a Phillips #00 screwdriver.
      Ask FixBot
    4. Canon PowerShot ELPH330 HS Camera  Repair LCD Screen  Replacement: step 4, image 1 of 1
      • Remove the two screws on the right side with a Phillips #00 screwdriver.
      Ask FixBot
    5. Canon PowerShot ELPH330 HS Camera  Repair LCD Screen  Replacement: step 5, image 1 of 1
      • Using your fingers, carefully pry the case apart at the seam.
      Ask FixBot
    6. Canon PowerShot ELPH330 HS Camera  Repair LCD Screen  Replacement: step 6, image 1 of 2 Canon PowerShot ELPH330 HS Camera  Repair LCD Screen  Replacement: step 6, image 2 of 2
      • Flip the camera over so that the lens is facing you.
      • Disconnect the highlighted port from the motherboard.
      Ask FixBot
    7. Canon PowerShot ELPH330 HS Camera  Repair LCD Screen  Replacement: step 7, image 1 of 2 Canon PowerShot ELPH330 HS Camera  Repair LCD Screen  Replacement: step 7, image 2 of 2
      • Remove the bracket around the LCD screen.
      Ask FixBot
    8. Canon PowerShot ELPH330 HS Camera  Repair LCD Screen  Replacement: step 8, image 1 of 1
      • Using the spudger, carefully pry the top to remove the LCD screen.
      Ask FixBot
Michelle Ngo
595 Reputation
3 Guides authored
UW Tacoma, Team S1-G3, Liner Summer 2019 Member of UW Tacoma, Team S1-G3, Liner Summer 2019
UWT-LINER-SU19S1G3
4 Members
36 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 20
Past 30 Days: 66
All Time: 1,240
