Canon PowerShot ELPH 300HS Power Button Replacement
Views: 3.2K
View statistics:
Past 24 Hours:
Past 7 Days:
14
Past 30 Days:
83
All Time:
3,157
Comments: 1
1 comment on steps.
Completed: 0
Favorites: 0
Time Required: 15 - 30 minutes
Difficulty: Moderate
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Markup Mishap
This guide needs better markups. Help out by correcting or making some markup annotations.
Introduction
Go to step 1 ↓
This will tell you how to replace a damaged power button.
Parts
Tools
  • Spudger
    4.9
    1. Canon PowerShot ELPH 300HS Power Button Replacement, Safety First: step 1, image 1 of 1
      • Before starting the repair, you must:
      • Turn off your camera by pressing the power button. (located next to "ON/OFF")
      Ask FixBot
    2. Canon PowerShot ELPH 300HS Power Button Replacement, Remove the Battery: step 2, image 1 of 2 Canon PowerShot ELPH 300HS Power Button Replacement, Remove the Battery: step 2, image 2 of 2
      • Locate the battery door on the bottom right area of the camera case.
      • Place your finger firmly on the black rubber pad on the battery door and slide the door to the right to open it.
      • Locate the orange battery release button beneath the battery door.
      • Slide the battery release button downward to release the battery.
      Ask FixBot
    3. Canon PowerShot ELPH 300HS Power Button Replacement, Left Side Screws: step 3, image 1 of 2 Canon PowerShot ELPH 300HS Power Button Replacement, Left Side Screws: step 3, image 2 of 2
      • Be careful when removing screws, as they are stripped easily.
      • Remove the two screws located on the left side of the camera case, using: (Phillips #00 screwdriver) (2.0 mm).
      Ask FixBot
    4. Canon PowerShot ELPH 300HS Power Button Replacement, Bottom Screws: step 4, image 1 of 1
      • Remove the two screws on the bottom of the camera located near the battery door (Phillips #00 screwdriver) (2.0 mm).
      Ask FixBot
    5. Canon PowerShot ELPH 300HS Power Button Replacement, Right Side Screws: step 5, image 1 of 1
      • Remove the screw located on the lower right side of the camera case using the same screwdriver in the previous steps (Phillips #00 screwdriver) (2.0 mm).
      • Remove the HDMI A/V out port cover located on the upper right side of the camera.
      • Remove the screw located just beneath the port cover removed in step 2. (Phillips #00 screwdriver) (2.0 mm).
      Ask FixBot
    6. Canon PowerShot ELPH 300HS Power Button Replacement: step 6, image 1 of 1
      • Remove the back portion of the camera case to reveal the screw located on the top of the case.
      • Remove the screw from the top of camera case, located next to the shutter button (Phillips #00 screwdriver) (2.0 mm).
      Ask FixBot
    7. Canon PowerShot ELPH 300HS Power Button Replacement, Remove the Case from the Camera: step 7, image 1 of 3 Canon PowerShot ELPH 300HS Power Button Replacement, Remove the Case from the Camera: step 7, image 2 of 3 Canon PowerShot ELPH 300HS Power Button Replacement, Remove the Case from the Camera: step 7, image 3 of 3
      • Be careful not to over bend the small metal projections located along the seams. These aid in holding the case together.
      • Be careful not to allow dust or other particles to settle inside of the camera while the case is detached. This can cause functional issues in the future.
      • Carefully pry the case apart at the seem, using your fingers.
      Ask FixBot
    1. Canon PowerShot ELPH 300HS Power Button Replacement, Power Button: step 8, image 1 of 2 Canon PowerShot ELPH 300HS Power Button Replacement, Power Button: step 8, image 2 of 2
      • Disconnect the small cable from the yellow port on the motherboard
      Ask FixBot
    2. Canon PowerShot ELPH 300HS Power Button Replacement: step 9, image 1 of 1
      • Disconnect the small cable from the blue port on the motherboard
      Ask FixBot
    3. Canon PowerShot ELPH 300HS Power Button Replacement: step 10, image 1 of 1
      • Lift the plastic over the HDMI port on the side of the camera
      Ask FixBot
    4. Canon PowerShot ELPH 300HS Power Button Replacement: step 11, image 1 of 2 Canon PowerShot ELPH 300HS Power Button Replacement: step 11, image 2 of 2
      • Lift from the back of the camera, angling forward and pull off to remove the power button assembly
      Ask FixBot
Kathryn Van Susante
697 Reputation
5 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 14
Past 30 Days: 83
All Time: 3,157
