Shop the Holiday Gift Guide
Canon PowerShot ELPH 300HS LCD Screen Replacement
Views: 6.5K
View statistics:
Past 24 Hours:
4
Past 7 Days:
30
Past 30 Days:
187
All Time:
6,497
Comments: 1
1 comment on steps.
Completed: 0
Favorites: 0
Time Required: 15 - 20 minutes
Difficulty: Moderate
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Markup Mishap
This guide needs better markups. Help out by correcting or making some markup annotations.
Better Introduction
Improve this guide by completing or revising its introduction.
Introduction
Go to step 1 ↓
This will show you how to replace the LCD screen on the back of your camera.
Parts
Tools
  • Spudger
    4.9
    1. Canon PowerShot ELPH 300HS LCD Screen Replacement, Safety First: step 1, image 1 of 1
      • Before starting the repair, you must:
      • Turn off your camera by pressing the power button. (located next to "ON/OFF")
      Ask FixBot
    2. Canon PowerShot ELPH 300HS LCD Screen Replacement, Remove the Battery: step 2, image 1 of 2 Canon PowerShot ELPH 300HS LCD Screen Replacement, Remove the Battery: step 2, image 2 of 2
      • Locate the battery door on the bottom right area of the camera case.
      • Place your finger firmly on the black rubber pad on the battery door and slide the door to the right to open it.
      • Locate the orange battery release button beneath the battery door.
      • Slide the battery release button downward to release the battery.
      Ask FixBot
    3. Canon PowerShot ELPH 300HS LCD Screen Replacement, Left Side Screws: step 3, image 1 of 2 Canon PowerShot ELPH 300HS LCD Screen Replacement, Left Side Screws: step 3, image 2 of 2
      • Be careful when removing screws, as they are stripped easily.
      • Remove the two screws located on the left side of the camera case, using: (Phillips #00 screwdriver) (2.0 mm).
      Ask FixBot
    4. Canon PowerShot ELPH 300HS LCD Screen Replacement, Bottom Screws: step 4, image 1 of 1
      • Remove the two screws on the bottom of the camera located near the battery door (Phillips #00 screwdriver) (2.0 mm).
      Ask FixBot
    5. Canon PowerShot ELPH 300HS LCD Screen Replacement, Right Side Screws: step 5, image 1 of 1
      • Remove the screw located on the lower right side of the camera case using the same screwdriver in the previous steps (Phillips #00 screwdriver) (2.0 mm).
      • Remove the HDMI A/V out port cover located on the upper right side of the camera.
      • Remove the screw located just beneath the port cover removed in step 2. (Phillips #00 screwdriver) (2.0 mm).
      Ask FixBot
    6. Canon PowerShot ELPH 300HS LCD Screen Replacement: step 6, image 1 of 1
      • Remove the back portion of the camera case to reveal the screw located on the top of the case.
      • Remove the screw from the top of camera case, located next to the shutter button (Phillips #00 screwdriver) (2.0 mm).
      Ask FixBot
    7. Canon PowerShot ELPH 300HS LCD Screen Replacement, Remove the Case from the Camera: step 7, image 1 of 3 Canon PowerShot ELPH 300HS LCD Screen Replacement, Remove the Case from the Camera: step 7, image 2 of 3 Canon PowerShot ELPH 300HS LCD Screen Replacement, Remove the Case from the Camera: step 7, image 3 of 3
      • Be careful not to over bend the small metal projections located along the seams. These aid in holding the case together.
      • Be careful not to allow dust or other particles to settle inside of the camera while the case is detached. This can cause functional issues in the future.
      • Carefully pry the case apart at the seem, using your fingers.
      Ask FixBot
    1. Canon PowerShot ELPH 300HS LCD Screen Replacement, LCD Screen: step 8, image 1 of 2 Canon PowerShot ELPH 300HS LCD Screen Replacement, LCD Screen: step 8, image 2 of 2
      • Disconnect the copper ribbon next to the blue port on the motherboard.
      Ask FixBot
    2. Canon PowerShot ELPH 300HS LCD Screen Replacement: step 9, image 1 of 3 Canon PowerShot ELPH 300HS LCD Screen Replacement: step 9, image 2 of 3 Canon PowerShot ELPH 300HS LCD Screen Replacement: step 9, image 3 of 3
      • Remove the L shaped bracket around the top and right side of the LCD screen.
      Ask FixBot
    3. Canon PowerShot ELPH 300HS LCD Screen Replacement: step 10, image 1 of 3 Canon PowerShot ELPH 300HS LCD Screen Replacement: step 10, image 2 of 3 Canon PowerShot ELPH 300HS LCD Screen Replacement: step 10, image 3 of 3
      • Insert the flat side of the spudger tool carefully on the top of the LCD screen and lift the screen free.
      Ask FixBot
Kathryn Van Susante
697 Reputation
5 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 30
Past 30 Days: 187
All Time: 6,497
