Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Markup Mishap
This guide needs better markups. Help out by correcting or making some markup annotations.
Better Introduction
Improve this guide by completing or revising its introduction.
Student In Progress
This guide is being worked on by hardworking students.
Introduction
Go to step 1 ↓In this guide, I will walk you through how to disassemble your Canon PowerShot ELPH 300 HS to get to your flash. Before you start, remember, the camera's internals hold some electric charge to them, so follow the steps carefully and ensure you have all of the necessary tools needed for this disassembly. Keep track of your screws as you follow along with the guide, and you will have you camera working brand new in no time! The video uploaded below offers an overview of this camera.
Video Overview
Turn off your camera by pressing the power button. (located next to "ON/OFF")
Locate the battery door on the bottom right area of the camera case.
Place your finger firmly on the black rubber pad on the battery door and slide the door to the right to open it.
Locate the orange battery release button beneath the battery door.
Slide the battery release button downward to release the battery.
Remove the two screws located on the left side of the camera case, using: (Phillips #00 screwdriver) (2.0 mm).
Remove the two screws on the bottom of the camera located near the battery door (Phillips #00 screwdriver) (2.0 mm).
Remove the screw located on the lower right side of the camera case using the same screwdriver in the previous steps (Phillips #00 screwdriver) (2.0 mm).
Remove the HDMI A/V out port cover located on the upper right side of the camera.
Remove the screw located just beneath the port cover removed in step 2. (Phillips #00 screwdriver) (2.0 mm).
Carefully pry the case apart at the seem, using your fingers.
Carefully remove the large copper ribbon on the front of the camera (attached with adhesive pads).
This guide only covers disassembly, so follow the steps in reverse to reassemble the camera. Any troubleshooting may be done through the Canon Official Site. However, since this camera has been discontinued, alternative cameras you may want to purchase include the PowerShot V1, the PowerShot SX740 HS, or the PowerShot ELPH 360 HS. If you wish to recycle or turn in your camera, further information can be found here: R2 or e-Stewards certified recycler.
2 other people completed this guide.
