Up to 20% off select tools
Canon PowerShot ELPH 300HS Back Panel Button Replacement
Views: 1.5K
View statistics:
Past 24 Hours:
2
Past 7 Days:
15
Past 30 Days:
96
All Time:
1,488
Comments: 1
1 comment on steps.
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 - 10 minutes
Difficulty: Easy
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Markup Mishap
This guide needs better markups. Help out by correcting or making some markup annotations.
Tools
Introduction
Go to step 1 ↓
In this guide you will learn how to replace broken buttons on the Back Panel of your Canon PowerShot ELPH 300HS. Replacing these buttons is usually a simple and inexpensive alternative to having you camera repaired at a shop or replaced.
    1. Canon PowerShot ELPH 300HS Back Panel Button Replacement, Safety First: step 1, image 1 of 1
      • Before starting the repair, you must:
      • Turn off the camera by pressing the power button located next to the “ON/OFF” label. Wait until the lens retracts completely and the screen turns off. Remove the battery and memory card before continuing to prevent accidental activation or damage to the camera’s internal components.
      Ask FixBot
    2. Canon PowerShot ELPH 300HS Back Panel Button Replacement, Remove the Battery: step 2, image 1 of 2 Canon PowerShot ELPH 300HS Back Panel Button Replacement, Remove the Battery: step 2, image 2 of 2
      • Locate the battery door on the bottom right area of the camera case.
      • Place your finger firmly on the black rubber pad on the battery door and slide the door to the right to open it.
      • Locate the orange battery release button beneath the battery door.
      • Slide the battery release button downward to release the battery.
      Ask FixBot
    3. Canon PowerShot ELPH 300HS Back Panel Button Replacement, Left Side Screws: step 3, image 1 of 2 Canon PowerShot ELPH 300HS Back Panel Button Replacement, Left Side Screws: step 3, image 2 of 2
      • Be careful when removing screws, as they are stripped easily.
      • Remove the two screws on the left side of the camera case using a Phillips #00 (2.0 mm) screwdriver.
      Ask FixBot
    4. Canon PowerShot ELPH 300HS Back Panel Button Replacement, Bottom Screws: step 4, image 1 of 1
      • Remove the two screws on the bottom of the camera located near the battery door (Phillips #00 screwdriver) (2.0 mm).
      Ask FixBot
    5. Canon PowerShot ELPH 300HS Back Panel Button Replacement, Right Side Screws: step 5, image 1 of 1
      • Remove the screw located on the lower right side of the camera case using the same screwdriver in the previous steps (Phillips #00 screwdriver) (2.0 mm).
      • Remove the HDMI A/V out port cover located on the upper right side of the camera.
      • Remove the screw located just beneath the port cover removed in step 2. (Phillips #00 screwdriver) (2.0 mm).
      Ask FixBot
    6. Canon PowerShot ELPH 300HS Back Panel Button Replacement: step 6, image 1 of 1
      • Remove the back portion of the camera case to reveal the screw located on the top of the case.
      • Remove the screw from the top of camera case, located next to the shutter button (Phillips #00 screwdriver) (2.0 mm).
      Ask FixBot
    7. Canon PowerShot ELPH 300HS Back Panel Button Replacement, Remove the Case from the Camera: step 7, image 1 of 3 Canon PowerShot ELPH 300HS Back Panel Button Replacement, Remove the Case from the Camera: step 7, image 2 of 3 Canon PowerShot ELPH 300HS Back Panel Button Replacement, Remove the Case from the Camera: step 7, image 3 of 3
      • Be careful not to over bend the small metal projections located along the seams. These aid in holding the case together.
      • Be careful not to allow dust or other particles to settle inside of the camera while the case is detached. This can cause functional issues in the future.
      • Carefully separate the camera case by gently prying along the seam with your fingers.
      Ask FixBot
    1. Canon PowerShot ELPH 300HS Back Panel Button Replacement, Remove & Replace: step 8, image 1 of 1
      • Now that you have followed the steps to remove the case, you can remove the back panel of your camera and replace it with your new panel.
      Ask FixBot
    2. Canon PowerShot ELPH 300HS Back Panel Button Replacement, Reassemble: step 9, image 1 of 1
      • Now that you have replaced your back panel buttons, you can reassemble the device in reverse order of the instructions in the Camera Case Replacement guide.
      Ask FixBot
Author
with
Kristin Brusso
193 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 15
Past 30 Days: 96
All Time: 1,488
