Canon PowerShot A630 Front Panel Replacement
    1. Canon PowerShot A630 Front Panel Replacement, Front Panel: step 1, image 1 of 2 Canon PowerShot A630 Front Panel Replacement, Front Panel: step 1, image 2 of 2
      • Open the battery door by sliding the tab on the battery door while pushing the battery door away from the camera.
      • Remove batteries.
      Ask FixBot
    2. Canon PowerShot A630 Front Panel Replacement: step 2, image 1 of 2 Canon PowerShot A630 Front Panel Replacement: step 2, image 2 of 2
      • Remove the three indicated .2mm screws using a Phillips #00 screwdriver.
      • Gently pull off side-panel to remove it.
      Ask FixBot
    3. Canon PowerShot A630 Front Panel Replacement: step 3, image 1 of 1
      • Remove the two indicated .2mm screws using a Phillips #00 screwdriver.
      Ask FixBot
    4. Canon PowerShot A630 Front Panel Replacement: step 4, image 1 of 2 Canon PowerShot A630 Front Panel Replacement: step 4, image 2 of 2
      • Remove the indicated .2mm screw using a Phillips #00 screwdriver.
      • Remove the three .2mm screws located on the internal side of the top panel within the battery chamber using a Phillips #00 screwdriver.
      Ask FixBot
    5. Canon PowerShot A630 Front Panel Replacement: step 5, image 1 of 2 Canon PowerShot A630 Front Panel Replacement: step 5, image 2 of 2
      • Open 'DIGITAL A/V OUT' door on camera.
      Ask FixBot
    6. Canon PowerShot A630 Front Panel Replacement: step 6, image 1 of 1
      • Grip the sides of the top panel and gently pull to separate the top panel from the camera body.
      • The top panel will not completely detach.
      Ask FixBot
    7. Canon PowerShot A630 Front Panel Replacement: step 7, image 1 of 2 Canon PowerShot A630 Front Panel Replacement: step 7, image 2 of 2
      • Gently pull the front and back panels apart, and use a Phillips #00 screwdriver to remove the screw connecting the panels.
      • Gripping the top and bottom, gently pull the front panel away from the camera body to remove it.
      Ask FixBot
4 other people completed this guide.
Kelly Duggan
460 Reputation
3 Guides authored
Clemson, Team 2-5, Benson Fall 2014 Member of Clemson, Team 2-5, Benson Fall 2014
CLEM-BENSON-F14S2G5
4 Members
108 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 19
All Time: 1,254
