Up to 20% off select tools
Canon PowerShot A630 Back Panel Replacement
Views: 2.1K
View statistics:
Past 24 Hours:
4
Past 7 Days:
18
Past 30 Days:
104
All Time:
2,124
Comments: 2
2 comments on steps.
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 15 - 20 minutes
Difficulty: Moderate
Better Introduction
Improve this guide by completing or revising its introduction.
Tools
    1. Canon PowerShot A630 Back Panel Replacement, Front Panel: step 1, image 1 of 2 Canon PowerShot A630 Back Panel Replacement, Front Panel: step 1, image 2 of 2
      • Open the battery door by sliding the tab on the battery door while pushing the battery door away from the camera.
      • Remove batteries.
      Ask FixBot
    2. Canon PowerShot A630 Back Panel Replacement: step 2, image 1 of 2 Canon PowerShot A630 Back Panel Replacement: step 2, image 2 of 2
      • Remove the three indicated .2mm screws using a Phillips #00 screwdriver.
      • Gently pull off side-panel to remove it.
      Ask FixBot
    3. Canon PowerShot A630 Back Panel Replacement: step 3, image 1 of 1
      • Remove the two indicated .2mm screws using a Phillips #00 screwdriver.
      Ask FixBot
    4. Canon PowerShot A630 Back Panel Replacement: step 4, image 1 of 2 Canon PowerShot A630 Back Panel Replacement: step 4, image 2 of 2
      • Remove the indicated .2mm screw using a Phillips #00 screwdriver.
      • Remove the three .2mm screws located on the internal side of the top panel within the battery chamber using a Phillips #00 screwdriver.
      Ask FixBot
    5. Canon PowerShot A630 Back Panel Replacement: step 5, image 1 of 2 Canon PowerShot A630 Back Panel Replacement: step 5, image 2 of 2
      • Open 'DIGITAL A/V OUT' door on camera.
      Ask FixBot
    6. Canon PowerShot A630 Back Panel Replacement: step 6, image 1 of 1
      • Grip the sides of the top panel and gently pull to separate the top panel from the camera body.
      • The top panel will not completely detach.
      Ask FixBot
    7. Canon PowerShot A630 Back Panel Replacement: step 7, image 1 of 2 Canon PowerShot A630 Back Panel Replacement: step 7, image 2 of 2
      • Gently pull the front and back panels apart, and use a Phillips #00 screwdriver to remove the screw connecting the panels.
      • Gripping the top and bottom, gently pull the front panel away from the camera body to remove it.
      Ask FixBot
    1. Canon PowerShot A630 Back Panel Replacement, Back Panel: step 8, image 1 of 2 Canon PowerShot A630 Back Panel Replacement, Back Panel: step 8, image 2 of 2
      • Use the spudger to gently pull back the retaining clip and pull the ribbon out.
      • The top panel should now be completely detached from the camera.
      • Applying too much force to the spudger may damage the retaining clip.
      Ask FixBot
    2. Canon PowerShot A630 Back Panel Replacement: step 9, image 1 of 2 Canon PowerShot A630 Back Panel Replacement: step 9, image 2 of 2
      • Remove .2 mm screw using a #00 Philips screwdriver.
      • Gently pry off back panel to remove it.
      Ask FixBot
Author
with
Alicia Burns
645 Reputation
5 Guides authored
Clemson, Team 2-5, Benson Fall 2014 Member of Clemson, Team 2-5, Benson Fall 2014
CLEM-BENSON-F14S2G5
4 Members
108 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 18
Past 30 Days: 104
All Time: 2,124
