Canon PowerShot A620 Camera Housing Replacement
Views: 2.6K
View statistics:
Past 24 Hours:
3
Past 7 Days:
21
Past 30 Days:
100
All Time:
2,582
Comments: 1
1 guide comment.
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 15 - 30 minutes
Difficulty: Moderate
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Better Introduction
Improve this guide by completing or revising its introduction.
Tools
    1. Canon PowerShot A620 Camera Housing Replacement, Open Battery Door: step 1, image 1 of 3 Canon PowerShot A620 Camera Housing Replacement, Open Battery Door: step 1, image 2 of 3 Canon PowerShot A620 Camera Housing Replacement, Open Battery Door: step 1, image 3 of 3
      • Slide the tab on the battery door while pushing the battery door away from you. The battery door should pop open.
      Ask FixBot
    2. Canon PowerShot A620 Camera Housing Replacement, Insert Batteries: step 2, image 1 of 2 Canon PowerShot A620 Camera Housing Replacement, Insert Batteries: step 2, image 2 of 2
      • Insert AA batteries according to the diagram printed on the camera.
      • Close the battery door.
      Ask FixBot
    1. Canon PowerShot A620 Camera Housing Replacement, Side Panel: step 3, image 1 of 3 Canon PowerShot A620 Camera Housing Replacement, Side Panel: step 3, image 2 of 3 Canon PowerShot A620 Camera Housing Replacement, Side Panel: step 3, image 3 of 3
      • Unscrew the three Phillips #00 1.6x3mm screws on the side.
      • Lift loose panel from the case.
      • Unscrew the two Phillips #00 1.6x3mm screws that were previously hidden beneath the panel.
      Ask FixBot
    2. Canon PowerShot A620 Camera Housing Replacement, Bottom Panel: step 4, image 1 of 1
      • Unscrew the two Phillips #00 1.6x3mm screws on the bottom panel.
      Ask FixBot
    3. Canon PowerShot A620 Camera Housing Replacement, Battery Compartment: step 5, image 1 of 1
      • Open the battery door.
      • Unscrew the four Phillips #00 1.6x3mm screws in the battery compartment.
      Ask FixBot
    4. Canon PowerShot A620 Camera Housing Replacement, Terminal Cover: step 6, image 1 of 2 Canon PowerShot A620 Camera Housing Replacement, Terminal Cover: step 6, image 2 of 2
      • Lift the terminal cover on the side of the camera.
      • Unscrew the three Phillips #00 1.6x3mm screws beneath the terminal cover.
      Ask FixBot
    5. Canon PowerShot A620 Camera Housing Replacement, Top Panel: step 7, image 1 of 1
      • Gently pull the top panel to separate it from the case.
      • Although the top panel will now be free from the rest of the case, it will still be attached to the camera by a ribbon cable.
      Ask FixBot
    6. Canon PowerShot A620 Camera Housing Replacement, Front Panel: step 8, image 1 of 2 Canon PowerShot A620 Camera Housing Replacement, Front Panel: step 8, image 2 of 2
      • Gently pull the front panel to separate it from the camera.
      • The battery terminals are easy to access from this step.
      Ask FixBot
    7. Canon PowerShot A620 Camera Housing Replacement, Terminal Cover: step 9, image 1 of 2 Canon PowerShot A620 Camera Housing Replacement, Terminal Cover: step 9, image 2 of 2
      • Gently pull the terminal cover to separate it from the camera.
      Ask FixBot
    8. Canon PowerShot A620 Camera Housing Replacement, Memory Card Cover: step 10, image 1 of 2 Canon PowerShot A620 Camera Housing Replacement, Memory Card Cover: step 10, image 2 of 2
      • Slide the memory card cover down.
      • Unscrew the Phillips #00 1.6x3mm screw beneath the memory card cover.
      Ask FixBot
    9. Canon PowerShot A620 Camera Housing Replacement, Back Panel: step 11, image 1 of 2 Canon PowerShot A620 Camera Housing Replacement, Back Panel: step 11, image 2 of 2
      • Gently pull the back panel to separate it from the camera.
      Ask FixBot
2 other people completed this guide.
Jaime Abraham
350 Reputation
3 Guides authored
CSU Fullerton, Team 1-1, Bruce Fall 2014 Member of CSU Fullerton, Team 1-1, Bruce Fall 2014
CSUF-BRUCE-F14S1G1
3 Members
36 Guides authored
1 Guide Comment
Ottima spiegazione: é tutto facile quando la spiegazione é semplice ed univoca. Ma redigere istruzioni semplici é un'arte che non tutti possiedono.
Paolo Ravera - Reply Share
Past 24 Hours: 3
Past 7 Days: 21
Past 30 Days: 100
All Time: 2,582
