Canon PowerShot A590 IS LCD Screen Replacement
  1. Canon PowerShot A590 IS LCD Screen Replacement, Batteries: step 1, image 1 of 2 Canon PowerShot A590 IS LCD Screen Replacement, Batteries: step 1, image 2 of 2
    • The battery hatch is on the bottom of the camera.
    • CAUTION: Locate the switch to open the hatch and push gently toward the front of the camera. Too much force can break the hatch.
    • While the switch is pushed forward, pull the cover away from the camera.
    Ask FixBot
  2. Canon PowerShot A590 IS LCD Screen Replacement: step 2, image 1 of 1
    • This camera requires AA batteries.
    • To remove batteries, simply allow them to fall out of the camera.
    • Use a fingernail to lift the clock battery out of the camera.
    Ask FixBot
  3. Canon PowerShot A590 IS LCD Screen Replacement: step 3, image 1 of 1
    • When replacing the AA batteries, verify they are oriented correctly by following the (+) and (-) signs on the camera.
    Ask FixBot
  4. Canon PowerShot A590 IS LCD Screen Replacement, Back Cover: step 4, image 1 of 1
    • Remove the screw located under the rubber flap on the left side of the camera using a Phillips #00 screwdriver.
    Ask FixBot
  5. Canon PowerShot A590 IS LCD Screen Replacement: step 5, image 1 of 1
    • Remove the two screws located on the other side of the camera using a Phillips #00 screwdriver.
    Ask FixBot
  6. Canon PowerShot A590 IS LCD Screen Replacement: step 6, image 1 of 1
    • Remove the three screws located at the bottom of the camera using a Phillips #00 screwdriver.
    Ask FixBot
  7. Canon PowerShot A590 IS LCD Screen Replacement: step 7, image 1 of 1
    • Open the battery cover.
    • Using the iFixit opening tool, push up gently around all edges of the camera.
    Ask FixBot
  8. Canon PowerShot A590 IS LCD Screen Replacement, LCD Screen: step 8, image 1 of 1
    • Remove the four screws near the corners of the LCD using a Phillips #00 screwdriver.
    Ask FixBot
  9. Canon PowerShot A590 IS LCD Screen Replacement: step 9, image 1 of 1
    • CAUTION: The LCD is connected to the motherboard with different wires and a ribbon. Using too much force may disconnect these parts.
    • Gently lift the screen from the motherboard.
    • Keep the LCD pulled back in one hand.
    Ask FixBot
  10. Canon PowerShot A590 IS LCD Screen Replacement: step 10, image 1 of 1
    • Use an iFixit opening tool to pull the black retaining clip up and disconnect the ribbon.
    Ask FixBot
  11. Canon PowerShot A590 IS LCD Screen Replacement: step 11, image 1 of 2 Canon PowerShot A590 IS LCD Screen Replacement: step 11, image 2 of 2
    • Desolder the wires from the back of the LCD located in the bottom left corner.
    • Remove the solder from the wires.
    • Separate the LCD from the rest of the camera.
    Ask FixBot
Zach
284 Reputation
6 Guides authored
Cal Poly, Team 9-19, Regan Fall 2010 Member of Cal Poly, Team 9-19, Regan Fall 2010
CPSU-REGAN-F10S9G19
4 Members
14 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 58
All Time: 10,694
