Canon PowerShot A590 IS Flash Assembly Replacement
Views: 17K
View statistics:
Past 24 Hours:
4
Past 7 Days:
29
Past 30 Days:
112
All Time:
16,820
Comments: 5
3 comments on steps, 2 guide comments.
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 minutes
Difficulty: Difficult
Incorrect Tools
Help make this guide better by using the correct tools in images and/or text.
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Introduction
Go to step 1 ↓
This guide will instruct you how to remove the front and back covers from the camera and disassemble the flash in order to replace or repair it.
Tools
    1. Canon PowerShot A590 IS Flash Assembly Replacement, Batteries: step 1, image 1 of 2 Canon PowerShot A590 IS Flash Assembly Replacement, Batteries: step 1, image 2 of 2
      • The battery hatch is on the bottom of the camera.
      • CAUTION: Locate the switch to open the hatch and push gently toward the front of the camera. Too much force can break the hatch.
      • While the switch is pushed forward, pull the cover away from the camera.
      Ask FixBot
    2. Canon PowerShot A590 IS Flash Assembly Replacement: step 2, image 1 of 1
      • This camera requires AA batteries.
      • To remove batteries, simply allow them to fall out of the camera.
      • Use a fingernail to lift the clock battery out of the camera.
      Ask FixBot
    3. Canon PowerShot A590 IS Flash Assembly Replacement: step 3, image 1 of 1
      • When replacing the AA batteries, verify they are oriented correctly by following the (+) and (-) signs on the camera.
      Ask FixBot
    1. Canon PowerShot A590 IS Flash Assembly Replacement, Back Cover: step 4, image 1 of 1
      • Remove the screw located under the rubber flap on the left side of the camera using a Phillips #00 screwdriver.
      Ask FixBot
    2. Canon PowerShot A590 IS Flash Assembly Replacement: step 5, image 1 of 1
      • Remove the two screws located on the other side of the camera using a Phillips #00 screwdriver.
      Ask FixBot
    3. Canon PowerShot A590 IS Flash Assembly Replacement: step 6, image 1 of 1
      • Remove the three screws located at the bottom of the camera using a Phillips #00 screwdriver.
      Ask FixBot
    4. Canon PowerShot A590 IS Flash Assembly Replacement: step 7, image 1 of 1
      • Open the battery cover.
      • Using the iFixit opening tool, push up gently around all edges of the camera.
      Ask FixBot
    1. Canon PowerShot A590 IS Flash Assembly Replacement, Remove Lens Cover: step 8, image 1 of 1
      • Press and hold down the button shown in the blue circle.
      • While pressing the button, rotate the lens cover in a counter-clockwise direction to remove it.
      Ask FixBot
    2. Canon PowerShot A590 IS Flash Assembly Replacement, Remove Front Cover: step 9, image 1 of 2 Canon PowerShot A590 IS Flash Assembly Replacement, Remove Front Cover: step 9, image 2 of 2
      • Remove the front cover of the camera.
      • This may require a bit of force.
      Ask FixBot
    1. Canon PowerShot A590 IS Flash Assembly Replacement, Remove Plastic Covering: step 10, image 1 of 1
      • Remove the one (1) screw from the top of the camera, on the left side of the flash (looking from the front) using a Phillips #00 screwdriver.
      • Lift the black plastic covering off the circuit board.
      Ask FixBot
    2. Canon PowerShot A590 IS Flash Assembly Replacement, Remove Green Circuit Board: step 11, image 1 of 1
      • Remove the green circuit board from the top. Looking from the front of the camera, first lift the left side up above the black peg. The board should then slide out to the left.
      • The clear flash lens may fall out. Do not worry this will not affect the camera and can easily be placed back in its spot.
      Ask FixBot
    3. Canon PowerShot A590 IS Flash Assembly Replacement, Unsolder Circuit Board Cables: step 12, image 1 of 1
      • Unsolder the cables under the circuit board.
      Ask FixBot
    4. Canon PowerShot A590 IS Flash Assembly Replacement: step 13, image 1 of 1
      • The flash logic board can now be removed from the camera and replaced.
      Ask FixBot
3 other people completed this guide.
Zach
284 Reputation
6 Guides authored
Cal Poly, Team 9-19, Regan Fall 2010 Member of Cal Poly, Team 9-19, Regan Fall 2010
CPSU-REGAN-F10S9G19
4 Members
84 Guides authored
2 Guide Comments
Zach, can you show how to replace the Ring Release Button? The release button appears to be fixed to the front cover once it is removed. Can we purchase a replacement release button?
Jae Ennis - Reply Share
If it is the flash element that needs to be replace, I presume I will see it when I’m there.
Is this correct ?
effitech_structure@yahoo.com
Jean-François Rondeau - Reply Share
Past 24 Hours: 4
Past 7 Days: 29
Past 30 Days: 112
All Time: 16,820
