Canon PowerShot A590 IS Clock Battery Replacement
    1. Canon PowerShot A590 IS Clock Battery Replacement, Batteries: step 1, image 1 of 2 Canon PowerShot A590 IS Clock Battery Replacement, Batteries: step 1, image 2 of 2
      • The battery hatch is on the bottom of the camera.
      • CAUTION: Locate the switch to open the hatch and push gently toward the front of the camera. Too much force can break the hatch.
      • While the switch is pushed forward, pull the cover away from the camera.
      Ask FixBot
    2. Canon PowerShot A590 IS Clock Battery Replacement: step 2, image 1 of 1
      • This camera requires AA batteries.
      • To remove batteries, simply allow them to fall out of the camera.
      • Use a fingernail to lift the clock battery out of the camera.
      Ask FixBot
    3. Canon PowerShot A590 IS Clock Battery Replacement: step 3, image 1 of 1
      • When replacing the AA batteries, verify they are oriented correctly by following the (+) and (-) signs on the camera.
      Ask FixBot
    1. Canon PowerShot A590 IS Clock Battery Replacement, Locate Clock Battery: step 4, image 1 of 1
      • To access the clock battery, find the clock battery cover, shown here in the red square.
      Ask FixBot
    2. Canon PowerShot A590 IS Clock Battery Replacement, Remove Battery Tab: step 5, image 1 of 1
      • When accessing the clock battery, use a fingernail or similar small instrument to gently pull the tab out.
      Ask FixBot
    3. Canon PowerShot A590 IS Clock Battery Replacement, Remove Battery from Tab: step 6, image 1 of 1
      • Now that you have the tab and battery removed, use a fingernail or other small tool to remove the battery from the tab.
      • This battery is a CR1220 type watch battery.
      Ask FixBot
    4. Canon PowerShot A590 IS Clock Battery Replacement, Replacing Clock Battery: step 7, image 1 of 1
      • When replacing the clock battery, be sure to have the battery oriented properly, as shown in the picture.
      • Remember, the tab goes in with the exposed side of the battery facing towards the lens.
      Ask FixBot
13 other people completed this guide.
Matt Wolfe
411 Reputation
1 Guide authored
Cal Poly, Team 9-19, Regan Fall 2010 Member of Cal Poly, Team 9-19, Regan Fall 2010
CPSU-REGAN-F10S9G19
4 Members
84 Guides authored
9 Guide Comments
thanks its very useful forme
srikrishnan2003 - Reply Share
thank you, very useful for my old camera :)
agungsp2000 - Reply Share
Perfect! I never even knew I had this battery in there. Couldn't figure out why the date and time wouldn't stay set every time I shut it off. And then I found the answer here.
Thank you very much for the post!
sherlock261 - Reply Share
I'm a senior citizen and am not very good with modern technology. Been going crazy trying to set my clock in my digital camera. I didn't want to buy a new one because I have had this one for years (Power Shot A590) and didn't want to have to learn to use a newer one. Finally got smart enough to do a google search for an answer. Will get a new battery tomorrow and solve my problem. Thanks for the help!...the information age is good for something after all.
Pat Solomon - Reply Share
Wow this is a great site. I got the answer I needed right away. The instructions were clear, simple and correct. Thank you.
You are bookmarked.
jeffrey wales - Reply Share
Past 24 Hours: 6
Past 7 Days: 25
Past 30 Days: 72
All Time: 17,737
