Canon PowerShot A590 IS Back Cover Replacement
    1. Canon PowerShot A590 IS Back Cover Replacement, Batteries: step 1, image 1 of 2 Canon PowerShot A590 IS Back Cover Replacement, Batteries: step 1, image 2 of 2
      • The battery hatch is on the bottom of the camera.
      • CAUTION: Locate the switch to open the hatch and push gently toward the front of the camera. Too much force can break the hatch.
      • While the switch is pushed forward, pull the cover away from the camera.
      Ask FixBot
    2. Canon PowerShot A590 IS Back Cover Replacement: step 2, image 1 of 1
      • This camera requires AA batteries.
      • To remove batteries, simply allow them to fall out of the camera.
      • Use a fingernail to lift the clock battery out of the camera.
      Ask FixBot
    3. Canon PowerShot A590 IS Back Cover Replacement: step 3, image 1 of 1
      • When replacing the AA batteries, verify they are oriented correctly by following the (+) and (-) signs on the camera.
      Ask FixBot
    1. Canon PowerShot A590 IS Back Cover Replacement, Back Cover: step 4, image 1 of 1
      • Remove the screw located under the rubber flap on the left side of the camera using a Phillips #00 screwdriver.
      Ask FixBot
    2. Canon PowerShot A590 IS Back Cover Replacement: step 5, image 1 of 1
      • Remove the two screws located on the other side of the camera using a Phillips #00 screwdriver.
      Ask FixBot
    3. Canon PowerShot A590 IS Back Cover Replacement: step 6, image 1 of 1
      • Remove the three screws located at the bottom of the camera using a Phillips #00 screwdriver.
      Ask FixBot
    4. Canon PowerShot A590 IS Back Cover Replacement: step 7, image 1 of 1
      • Open the battery cover.
      • Using the iFixit opening tool, push up gently around all edges of the camera.
      Ask FixBot
8 other people completed this guide.
Zach
284 Reputation
6 Guides authored
Cal Poly, Team 9-19, Regan Fall 2010 Member of Cal Poly, Team 9-19, Regan Fall 2010
CPSU-REGAN-F10S9G19
4 Members
84 Guides authored
1 Guide Comment
i just wanted to by flap to replace over batteries it slides on and off reedalice270@gm.com
Alice Reed - Reply Share
Past 24 Hours: 2
Past 7 Days: 8
Past 30 Days: 51
All Time: 9,594
