Canon PowerShot A550 Internal Battery Replacement
Views: 17K
View statistics:
Past 24 Hours:
8
Past 7 Days:
44
Past 30 Days:
203
All Time:
17,174
Comments: 0
Go to guide comments
Completed: 6
6 people have marked this guide "completed." Will you be next?
Favorites: 2
2 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 2 - 5 minutes
Difficulty: Very easy
Introduction
Go to step 1 ↓
The internal battery is vital for powering your Canon Powershot A550. This guide will show you how to remove and replace your internal battery so that your camera may function properly with a new power supply.
Parts
Tools
    1. Canon PowerShot A550 Internal Battery Replacement, Internal Battery: step 1, image 1 of 2 Canon PowerShot A550 Internal Battery Replacement, Internal Battery: step 1, image 2 of 2
      • Open the compartment labeled CARD/BATT. located at the bottom of the camera by moving the dark gray button down and sliding the cover to the right.
      • The opened compartment should look like this.
      Ask FixBot
    2. Canon PowerShot A550 Internal Battery Replacement: step 2, image 1 of 2 Canon PowerShot A550 Internal Battery Replacement: step 2, image 2 of 2
      Tool used on this step:
      Buy
      • Use tweezers to remove the internal battery by sliding it up and out of its compartment.
      • The internal battery can now be replaced.
      Ask FixBot
6 other people completed this guide.
Precilla Tang
207 Reputation
2 Guides authored
Cal Poly, Team 8-6, Regan Spring 2011 Member of Cal Poly, Team 8-6, Regan Spring 2011
CPSU-REGAN-S11S8G6
4 Members
96 Guides authored
0 Guide Comments
Past 24 Hours: 8
Past 7 Days: 44
Past 30 Days: 203
All Time: 17,174
