Canon PowerShot A540 Front Cover Replacement
    1. Canon PowerShot A540 Front Cover Replacement, Back Cover: step 1, image 1 of 2 Canon PowerShot A540 Front Cover Replacement, Back Cover: step 1, image 2 of 2
      • Turn off the camera.
      • Turn the camera upside-down and press the tab to release the battery cover. Remove the batteries.
      Ask FixBot
    2. Canon PowerShot A540 Front Cover Replacement: step 2, image 1 of 1
      • Turn the camera upside down to view the "Card/Batt. Open" Cover.
      • Use a Phillips head #000 screwdriver to remove the three (3) 4.0 mm screws.
      Ask FixBot
    3. Canon PowerShot A540 Front Cover Replacement: step 3, image 1 of 1
      • Open "Card/Batt. Open" Cover.
      • Remove the one (1) 5.0 mm screw with the Phillips head #000 screwdriver.
      Ask FixBot
    4. Canon PowerShot A540 Front Cover Replacement: step 4, image 1 of 1
      • Turn the camera to the right side of the LCD screen.
      • Remove the three (3) 4.0 mm screws with the Phillips head #000 screwdriver.
      Ask FixBot
    5. Canon PowerShot A540 Front Cover Replacement: step 5, image 1 of 3 Canon PowerShot A540 Front Cover Replacement: step 5, image 2 of 3 Canon PowerShot A540 Front Cover Replacement: step 5, image 3 of 3
      • Gently remove the back cover.
      • Start at the bottom at the corner of the "Card/Batt. Open" Cover.
      • Then move onto the other edges and the top.
      • It may be tight at the top!
      Ask FixBot
    1. Canon PowerShot A540 Front Cover Replacement, Front Cover: step 6, image 1 of 2 Canon PowerShot A540 Front Cover Replacement, Front Cover: step 6, image 2 of 2
      • Turn the camera to view the front.
      • Remove the lens guard.
      • Press the lens guard's button as you turn the guard counterclockwise.
      Ask FixBot
    2. Canon PowerShot A540 Front Cover Replacement: step 7, image 1 of 1
      • Turn the camera to the side left of the LCD screen.
      • Remove the one (1) 4.0 mm screw with the Phillips head #000 screwdriver.
      Ask FixBot
    3. Canon PowerShot A540 Front Cover Replacement: step 8, image 1 of 1
      • Remove the front cover gently.
      • When removing the front cover, a thin, black rubber washer may fall off the lens. If it does, make sure to put it back on the lens before reassembly.
      Ask FixBot
2 other people completed this guide.
Carley Fuller
434 Reputation
3 Guides authored
Baylor, Team 7-12, Williams Spring 2015 Member of Baylor, Team 7-12, Williams Spring 2015
BU-WILLIAMS-S15S7G12
3 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 26
Past 30 Days: 46
All Time: 2,370
