Canon PowerShot A460 Motherboard Replacement
  1. Canon PowerShot A460 Motherboard Replacement, Battery: step 1, image 1 of 1
    • Slide the switch on the battery cover labeled "CARD/BATT. OPEN." to the right.
    • While still holding the switch, pull the cover down, allowing it to release and open.
    Ask FixBot
  2. Canon PowerShot A460 Motherboard Replacement: step 2, image 1 of 1
    • Tilt the camera slightly to allow the batteries to fall out.
    Ask FixBot
  3. Canon PowerShot A460 Motherboard Replacement: step 3, image 1 of 1
    • Press on and release the memory card to eject it.
    Ask FixBot
  4. Canon PowerShot A460 Motherboard Replacement, Front Casing: step 4, image 1 of 1
    • Unscrew the 5mm Phillips #00 screw from the bottom of the camera.
    • Make sure to keep the different size screws organized to make reassembling the camera simpler.
    Ask FixBot
  5. Canon PowerShot A460 Motherboard Replacement: step 5, image 1 of 1
    • Unscrew the three 2mm Phillips #00 screws that are located on the bottom of the camera.
    Ask FixBot
  6. Canon PowerShot A460 Motherboard Replacement: step 6, image 1 of 1
    • Remove the 4mm Phillips #00 screw that is located on the left side of the camera, if the display screen is facing you.
    Ask FixBot
  7. Canon PowerShot A460 Motherboard Replacement: step 7, image 1 of 1
    • Take out the 4mm Phillips #00 screw under the rubber flap on the right end of the camera.
    Ask FixBot
  8. Canon PowerShot A460 Motherboard Replacement: step 8, image 1 of 2 Canon PowerShot A460 Motherboard Replacement: step 8, image 2 of 2
    • Remove the second battery cover on the bottom of camera.
    • Take the silver battery out of the camera.
    Ask FixBot
  9. Canon PowerShot A460 Motherboard Replacement: step 9, image 1 of 3 Canon PowerShot A460 Motherboard Replacement: step 9, image 2 of 3 Canon PowerShot A460 Motherboard Replacement: step 9, image 3 of 3
    • Remove the 4mm Phillips #00 screw on the inside of the flap that hides the battery and memory card slots.
    • Remove the light grey, plastic piece.
    • Remove the plastic portion of the battery flap cover. The metal piece will remain attached.
    Ask FixBot
  10. Canon PowerShot A460 Motherboard Replacement: step 10, image 1 of 3 Canon PowerShot A460 Motherboard Replacement: step 10, image 2 of 3 Canon PowerShot A460 Motherboard Replacement: step 10, image 3 of 3
    • Slightly pull on each side of the camera. It should loosen up and come apart.
    • If it does not pull apart right away, use a little more force.
    • Do not give up!
    Ask FixBot
  11. Canon PowerShot A460 Motherboard Replacement, Back Casing: step 11, image 1 of 1
    • Remove the back case of the camera by pulling from the top.
    • Be careful when pulling off the case. There is a delicate gold ribbon connecting the bottom of the camera to the back case.
    Ask FixBot
  12. Canon PowerShot A460 Motherboard Replacement, LCD Screen: step 12, image 1 of 1
    • Remove the 4mm Phillips #00 screw from above the ribbon.
    Ask FixBot
  13. Canon PowerShot A460 Motherboard Replacement: step 13, image 1 of 1
    • Gently peel off the blue tape on the top of the LCD screen.
    Ask FixBot
  14. Canon PowerShot A460 Motherboard Replacement: step 14, image 1 of 1
    • Remove the 4mm Phillips #00 screw previously concealed by the blue tape.
    Ask FixBot
  15. Canon PowerShot A460 Motherboard Replacement: step 15, image 1 of 1
    • Gently lift the LCD screen off of the front casing by pulling up a tab on the side of the camera.
    Ask FixBot
  16. Canon PowerShot A460 Motherboard Replacement: step 16, image 1 of 1
    • Using a spudger, lift the grey tabs to allow the ribbon to slide out.
    Ask FixBot
  17. Canon PowerShot A460 Motherboard Replacement: step 17, image 1 of 1
    • Since the tabs have been lifted, the ribbon should now slide out out easily.
    • Be careful not to distort the ribbon in any way.
    Ask FixBot
  18. Canon PowerShot A460 Motherboard Replacement, Motherboard: step 18, image 1 of 1
    • Remove the 5mm Phillips #00 screw located above the small black piece on the right side of the mother board.
    Ask FixBot
  19. Canon PowerShot A460 Motherboard Replacement: step 19, image 1 of 2 Canon PowerShot A460 Motherboard Replacement: step 19, image 2 of 2
    • Remove the 4mm Phillips #00 screw at the bottom of the black piece.
    • Detach the black piece that the screws previously held in place.
    Ask FixBot
  20. Canon PowerShot A460 Motherboard Replacement: step 20, image 1 of 1
    • Remove the 5mm Phillips #00 screw in the middle of the motherboard.
    Ask FixBot
  21. Canon PowerShot A460 Motherboard Replacement: step 21, image 1 of 1
    • Remove the 5mm Phillips #00 screw that holds the metal piece to the bottom of the camera .
    Ask FixBot
  22. Canon PowerShot A460 Motherboard Replacement: step 22, image 1 of 1
    • Remove the 5mm Phillips #00 screw that is located on the top of camera.
    Ask FixBot
  23. Canon PowerShot A460 Motherboard Replacement: step 23, image 1 of 1
    • Remove the 2mm Phillips #00 screw that is located on the far left of the motherboard.
    • Be careful not to damage the multiple adjacent orange ribbons.
    Ask FixBot
  24. Canon PowerShot A460 Motherboard Replacement: step 24, image 1 of 1
    • Remove the 5mm Phillips #00 screw near the bottom left of the motherboard.
    Ask FixBot
  25. Canon PowerShot A460 Motherboard Replacement: step 25, image 1 of 2 Canon PowerShot A460 Motherboard Replacement: step 25, image 2 of 2
    • Using a spudger, unlock the locking mechanism that holds the lower orange ribbon in place.
    • Once unlocked, slide out the ribbon.
    Ask FixBot
  26. Canon PowerShot A460 Motherboard Replacement: step 26, image 1 of 1
    • Using a spudger, unlock the locking mechanism that holds the upper orange ribbon in place.
    Ask FixBot
  27. Canon PowerShot A460 Motherboard Replacement: step 27, image 1 of 1
    • All that is required is to unsolder the few remaining wires. Then, the motherboard will be ready to be replaced!
    Ask FixBot
2 other people completed this guide.
Tanner Coleman
61 Reputation
2 Guides authored
Cal Poly, Team 19-42, Regan Winter 2013 Member of Cal Poly, Team 19-42, Regan Winter 2013
CPSU-REGAN-W13S19G42
4 Members
12 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 39
All Time: 2,306
