Canon PowerShot A460 Front Lens Replacement
Views: 6K
View statistics:
Past 24 Hours:
5
Past 7 Days:
26
Past 30 Days:
129
All Time:
6,005
Comments: 4
3 comments on steps, 1 guide comment.
Go to guide comments
Completed: 4
4 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 1 hour
Difficulty: Difficult
Needs More Images
A few more images would make this guide's procedures crystal clear.
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Step Trimmer
This guide has unnecessary steps. Trim them to be more concise!
Introduction
Go to step 1 ↓
This guide will involve complete disassembly of the camera.
Tools
  • Phillips #00 Screwdriver
    4.9
  • Spudger
    4.9
    1. Canon PowerShot A460 Front Lens Replacement, Battery: step 1, image 1 of 1
      • Slide the switch on the battery cover labeled "CARD/BATT. OPEN." to the right.
      • While still holding the switch, pull the cover down, allowing it to release and open.
      Ask FixBot
    2. Canon PowerShot A460 Front Lens Replacement: step 2, image 1 of 1
      • Tilt the camera slightly to allow the batteries to fall out.
      Ask FixBot
    3. Canon PowerShot A460 Front Lens Replacement: step 3, image 1 of 1
      • Press on and release the memory card to eject it.
      Ask FixBot
    1. Canon PowerShot A460 Front Lens Replacement, Front Casing: step 4, image 1 of 1
      • Unscrew the 5mm Phillips #00 screw from the bottom of the camera.
      • Make sure to keep the different size screws organized to make reassembling the camera simpler.
      Ask FixBot
    2. Canon PowerShot A460 Front Lens Replacement: step 5, image 1 of 1
      • Unscrew the three 2mm Phillips #00 screws that are located on the bottom of the camera.
      Ask FixBot
    3. Canon PowerShot A460 Front Lens Replacement: step 6, image 1 of 1
      • Remove the 4mm Phillips #00 screw that is located on the left side of the camera, if the display screen is facing you.
      Ask FixBot
    4. Canon PowerShot A460 Front Lens Replacement: step 7, image 1 of 1
      • Take out the 4mm Phillips #00 screw under the rubber flap on the right end of the camera.
      Ask FixBot
    5. Canon PowerShot A460 Front Lens Replacement: step 8, image 1 of 2 Canon PowerShot A460 Front Lens Replacement: step 8, image 2 of 2
      • Remove the second battery cover on the bottom of camera.
      • Take the silver battery out of the camera.
      Ask FixBot
    6. Canon PowerShot A460 Front Lens Replacement: step 9, image 1 of 3 Canon PowerShot A460 Front Lens Replacement: step 9, image 2 of 3 Canon PowerShot A460 Front Lens Replacement: step 9, image 3 of 3
      • Remove the 4mm Phillips #00 screw on the inside of the flap that hides the battery and memory card slots.
      • Remove the light grey, plastic piece.
      • Remove the plastic portion of the battery flap cover. The metal piece will remain attached.
      Ask FixBot
    7. Canon PowerShot A460 Front Lens Replacement: step 10, image 1 of 3 Canon PowerShot A460 Front Lens Replacement: step 10, image 2 of 3 Canon PowerShot A460 Front Lens Replacement: step 10, image 3 of 3
      • Slightly pull on each side of the camera. It should loosen up and come apart.
      • If it does not pull apart right away, use a little more force.
      • Do not give up!
      Ask FixBot
    1. Canon PowerShot A460 Front Lens Replacement, Back Casing: step 11, image 1 of 1
      • Remove the back case of the camera by pulling from the top.
      • Be careful when pulling off the case. There is a delicate gold ribbon connecting the bottom of the camera to the back case.
      Ask FixBot
    1. Canon PowerShot A460 Front Lens Replacement, LCD Screen: step 12, image 1 of 1
      • Remove the 4mm Phillips #00 screw from above the ribbon.
      Ask FixBot
    2. Canon PowerShot A460 Front Lens Replacement: step 13, image 1 of 1
      • Gently peel off the blue tape on the top of the LCD screen.
      Ask FixBot
    3. Canon PowerShot A460 Front Lens Replacement: step 14, image 1 of 1
      • Remove the 4mm Phillips #00 screw previously concealed by the blue tape.
      Ask FixBot
    4. Canon PowerShot A460 Front Lens Replacement: step 15, image 1 of 1
      • Gently lift the LCD screen off of the front casing by pulling up a tab on the side of the camera.
      Ask FixBot
    5. Canon PowerShot A460 Front Lens Replacement: step 16, image 1 of 1
      • Using a spudger, lift the grey tabs to allow the ribbon to slide out.
      Ask FixBot
    6. Canon PowerShot A460 Front Lens Replacement: step 17, image 1 of 1
      • Since the tabs have been lifted, the ribbon should now slide out out easily.
      • Be careful not to distort the ribbon in any way.
      Ask FixBot
    1. Canon PowerShot A460 Front Lens Replacement, Motherboard: step 18, image 1 of 1
      • Remove the 5mm Phillips #00 screw located above the small black piece on the right side of the mother board.
      Ask FixBot
    2. Canon PowerShot A460 Front Lens Replacement: step 19, image 1 of 2 Canon PowerShot A460 Front Lens Replacement: step 19, image 2 of 2
      • Remove the 4mm Phillips #00 screw at the bottom of the black piece.
      • Detach the black piece that the screws previously held in place.
      Ask FixBot
    3. Canon PowerShot A460 Front Lens Replacement: step 20, image 1 of 1
      • Remove the 5mm Phillips #00 screw in the middle of the motherboard.
      Ask FixBot
    4. Canon PowerShot A460 Front Lens Replacement: step 21, image 1 of 1
      • Remove the 5mm Phillips #00 screw that holds the metal piece to the bottom of the camera .
      Ask FixBot
    5. Canon PowerShot A460 Front Lens Replacement: step 22, image 1 of 1
      • Remove the 5mm Phillips #00 screw that is located on the top of camera.
      Ask FixBot
    6. Canon PowerShot A460 Front Lens Replacement: step 23, image 1 of 1
      • Remove the 2mm Phillips #00 screw that is located on the far left of the motherboard.
      • Be careful not to damage the multiple adjacent orange ribbons.
      Ask FixBot
    7. Canon PowerShot A460 Front Lens Replacement: step 24, image 1 of 1
      • Remove the 5mm Phillips #00 screw near the bottom left of the motherboard.
      Ask FixBot
    8. Canon PowerShot A460 Front Lens Replacement: step 25, image 1 of 2 Canon PowerShot A460 Front Lens Replacement: step 25, image 2 of 2
      • Using a spudger, unlock the locking mechanism that holds the lower orange ribbon in place.
      • Once unlocked, slide out the ribbon.
      Ask FixBot
    9. Canon PowerShot A460 Front Lens Replacement: step 26, image 1 of 1
      • Using a spudger, unlock the locking mechanism that holds the upper orange ribbon in place.
      Ask FixBot
    10. Canon PowerShot A460 Front Lens Replacement: step 27, image 1 of 1
      • All that is required is to unsolder the few remaining wires. Then, the motherboard will be ready to be replaced!
      Ask FixBot
    1. Canon PowerShot A460 Front Lens Replacement, Front Lens: step 28, image 1 of 1
      • Remove the six 2mm Phillips #00 screws that are located under the motherboard.
      Ask FixBot
    2. Canon PowerShot A460 Front Lens Replacement: step 29, image 1 of 2 Canon PowerShot A460 Front Lens Replacement: step 29, image 2 of 2
      • Remove the 4mm Phillips #00 screw that is located under the now disconnected top orange ribbon.
      • The lens piece can now be removed from the camera.
      Ask FixBot
    3. Canon PowerShot A460 Front Lens Replacement: step 30, image 1 of 1
      • Remove the 5mm Phillips #00 screw on the back of the lens piece.
      Ask FixBot
    4. Canon PowerShot A460 Front Lens Replacement: step 31, image 1 of 1
      • Remove the 2mm Phillips #00 screw on the bottom of the lens piece.
      Ask FixBot
    5. Canon PowerShot A460 Front Lens Replacement: step 32, image 1 of 1
      • Remove the two 2mm Phillips #00 screws on the top of the lens piece.
      Ask FixBot
    6. Canon PowerShot A460 Front Lens Replacement: step 33, image 1 of 1
      • Gently slide off the black piece surrounding the lens. The lens is now disassembled!
      Ask FixBot
4 other people completed this guide.
Tanner Coleman
61 Reputation
2 Guides authored
Cal Poly, Team 19-42, Regan Winter 2013 Member of Cal Poly, Team 19-42, Regan Winter 2013
CPSU-REGAN-W13S19G42
4 Members
72 Guides authored
1 Guide Comment
please put a big warning note on the step after removing the blue tape from the lens. and the next on is where you lift something on the mother board with a spluger..something like that. well i used a screwdriver and got such a big electrical shock.... scared the crapola out of me. please make a note .... can get electrical shock....
Gaby - Reply Share
Past 24 Hours: 5
Past 7 Days: 26
Past 30 Days: 129
All Time: 6,005
