Canon PowerShot A460 Front Casing Replacement
    1. Canon PowerShot A460 Front Casing Replacement, Battery: step 1, image 1 of 1
      • Slide the switch on the battery cover labeled "CARD/BATT. OPEN." to the right.
      • While still holding the switch, pull the cover down, allowing it to release and open.
      Ask FixBot
    2. Canon PowerShot A460 Front Casing Replacement: step 2, image 1 of 1
      • Tilt the camera slightly to allow the batteries to fall out.
      Ask FixBot
    3. Canon PowerShot A460 Front Casing Replacement: step 3, image 1 of 1
      • Press on and release the memory card to eject it.
      Ask FixBot
    1. Canon PowerShot A460 Front Casing Replacement, Front Casing: step 4, image 1 of 1
      • Unscrew the 5mm Phillips #00 screw from the bottom of the camera.
      • Make sure to keep the different size screws organized to make reassembling the camera simpler.
      Ask FixBot
    2. Canon PowerShot A460 Front Casing Replacement: step 5, image 1 of 1
      • Unscrew the three 2mm Phillips #00 screws that are located on the bottom of the camera.
      Ask FixBot
    3. Canon PowerShot A460 Front Casing Replacement: step 6, image 1 of 1
      • Remove the 4mm Phillips #00 screw that is located on the left side of the camera, if the display screen is facing you.
      Ask FixBot
    4. Canon PowerShot A460 Front Casing Replacement: step 7, image 1 of 1
      • Take out the 4mm Phillips #00 screw under the rubber flap on the right end of the camera.
      Ask FixBot
    5. Canon PowerShot A460 Front Casing Replacement: step 8, image 1 of 2 Canon PowerShot A460 Front Casing Replacement: step 8, image 2 of 2
      • Remove the second battery cover on the bottom of camera.
      • Take the silver battery out of the camera.
      Ask FixBot
    6. Canon PowerShot A460 Front Casing Replacement: step 9, image 1 of 3 Canon PowerShot A460 Front Casing Replacement: step 9, image 2 of 3 Canon PowerShot A460 Front Casing Replacement: step 9, image 3 of 3
      • Remove the 4mm Phillips #00 screw on the inside of the flap that hides the battery and memory card slots.
      • Remove the light grey, plastic piece.
      • Remove the plastic portion of the battery flap cover. The metal piece will remain attached.
      Ask FixBot
    7. Canon PowerShot A460 Front Casing Replacement: step 10, image 1 of 3 Canon PowerShot A460 Front Casing Replacement: step 10, image 2 of 3 Canon PowerShot A460 Front Casing Replacement: step 10, image 3 of 3
      • Slightly pull on each side of the camera. It should loosen up and come apart.
      • If it does not pull apart right away, use a little more force.
      • Do not give up!
      Ask FixBot
2 other people completed this guide.
Alex
112 Reputation
2 Guides authored
Cal Poly, Team 19-42, Regan Winter 2013 Member of Cal Poly, Team 19-42, Regan Winter 2013
CPSU-REGAN-W13S19G42
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 30
All Time: 1,459
