Canon PowerShot A2300 Flash Assembly Replacement
Views: 2.8K
View statistics:
Past 24 Hours:
2
Past 7 Days:
22
Past 30 Days:
120
All Time:
2,830
Comments: 0
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 25 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
This guide will allow the reader to replace the flash by walking through the steps disassembly steps required to reach the flash. It is first necessary to remove the front and back covers as well as reach the back of the display screen.
Tools
  • Spudger
    4.9
  • Phillips #00 Screwdriver
    4.9
    1. Canon PowerShot A2300 Flash Assembly Replacement, Front Cover: step 1, image 1 of 1
      • Open the A/V Out Digital port cover on the function button side to reveal a screw.
      Ask FixBot
    2. Canon PowerShot A2300 Flash Assembly Replacement: step 2, image 1 of 3 Canon PowerShot A2300 Flash Assembly Replacement: step 2, image 2 of 3 Canon PowerShot A2300 Flash Assembly Replacement: step 2, image 3 of 3
      • Remove all 6 screws(2.70 mm), 2 on each side and 2 on the bottom.
      • Screws are small and very easily lost.
      Ask FixBot
    3. Canon PowerShot A2300 Flash Assembly Replacement: step 3, image 1 of 2 Canon PowerShot A2300 Flash Assembly Replacement: step 3, image 2 of 2
      • Open the card/battery latch by sliding the cover away from the camera in the direction indicated by the arrow.
      • Doing this gives a spot to grip on the bottom of the front cover. This will make it easier to handle when removing.
      Ask FixBot
    4. Canon PowerShot A2300 Flash Assembly Replacement: step 4, image 1 of 1
      • Gently lift the bottom of the front cover to roughly a 30 degree angle.
      Ask FixBot
    5. Canon PowerShot A2300 Flash Assembly Replacement: step 5, image 1 of 1
      • Pull the top of the front cover away from the camera by gripping the top of the front cover by the corners where the cover is still attached to the body.
      Ask FixBot
    1. Canon PowerShot A2300 Flash Assembly Replacement, Back Cover: step 6, image 1 of 1
      • Hold the camera in your hands with both thumbs on the screen with the screen faced up.
      • Keep close to the table top in case the camera falls out of your hands.
      Ask FixBot
    2. Canon PowerShot A2300 Flash Assembly Replacement: step 7, image 1 of 1
      • Pull the the bottom left corner of the cover up about an inch to the point shown in the picture.
      • Do not completely remove the back cover by pulling on the side as shown. The cover is still attached on the top of the camera.
      Ask FixBot
    3. Canon PowerShot A2300 Flash Assembly Replacement: step 8, image 1 of 1
      • Pry the top off by sliding the spudger under the On/Off button.
      Ask FixBot
    4. Canon PowerShot A2300 Flash Assembly Replacement: step 9, image 1 of 1
      • Slide the cover to the right and off the camera.
      • Gently pry using the spudger on the right side if necessary.
      • The A/V OUT DIGITAL cover will sometimes become loose and disconnect from the cover
      Ask FixBot
    1. Canon PowerShot A2300 Flash Assembly Replacement, Flash Assembly: step 10, image 1 of 1
      • Raise the screen by wedging the spudger between the bottom of the screen and the mount hole.
      Ask FixBot
    2. Canon PowerShot A2300 Flash Assembly Replacement: step 11, image 1 of 1
      • Remove the metal sheet that is under the screen.
      Ask FixBot
    3. Canon PowerShot A2300 Flash Assembly Replacement: step 12, image 1 of 1
      • Remove the top left screw on the metal sheet that is behind the screen.
      • This screw connects the flash to the metal sheet.
      Ask FixBot
    4. Canon PowerShot A2300 Flash Assembly Replacement: step 13, image 1 of 1
      Tool used on this step:
      Buy
      • Use one side of the tweezers to raise the orange retaining flap on the zero insertion force (ZIF) connector to a vertical position.
      Ask FixBot
    5. Canon PowerShot A2300 Flash Assembly Replacement: step 14, image 1 of 1
      • Gently pull the orange ribbon cable out of the ZIF connector using the tweezers.
      Ask FixBot
    6. Canon PowerShot A2300 Flash Assembly Replacement: step 15, image 1 of 2 Canon PowerShot A2300 Flash Assembly Replacement: step 15, image 2 of 2
      • Remove the flash by gently rotating slightly back and forth and pulling up.
      Ask FixBot
3 other people completed this guide.
Nathan McMillan
405 Reputation
2 Guides authored
Baylor, Team 7-14, Williams Spring 2015 Member of Baylor, Team 7-14, Williams Spring 2015
BU-WILLIAMS-S15S7G14
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 22
Past 30 Days: 120
All Time: 2,830
