Up to 20% off select tools
Canon PowerShot A2200 Back Cover Replacement
Views: 1.9K
View statistics:
Past 24 Hours:
2
Past 7 Days:
18
Past 30 Days:
108
All Time:
1,917
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 5 minutes
Difficulty: Easy
Tools
Introduction
Go to step 1 ↓
This replacement guide requires you to remove the screws that hold the back cover of the camera in place. This will allow you to replace the back cover as well as have access to other parts of the camera.
    1. Canon PowerShot A2200 Back Cover Replacement, Back Cover: step 1, image 1 of 1
      • First, remove the batteries and memory card.
      • Remove the 5.0 mm black screw with a Phillips #00 screwdriver.
      • Remove the 5.0 mm silver screw with a Phillips #00 screwdriver.
      Ask FixBot
    2. Canon PowerShot A2200 Back Cover Replacement: step 2, image 1 of 1
      • Remove the 5.0 mm black screw on the right with a Phillips #00 screwdriver.
      Ask FixBot
    3. Canon PowerShot A2200 Back Cover Replacement: step 3, image 1 of 1
      • Remove the 5.0 mm screw on the left with a Phillips #00 screwdriver.
      Ask FixBot
    4. Canon PowerShot A2200 Back Cover Replacement: step 4, image 1 of 3 Canon PowerShot A2200 Back Cover Replacement: step 4, image 2 of 3 Canon PowerShot A2200 Back Cover Replacement: step 4, image 3 of 3
      • Begin taking off the back cover with a plastic opening tool.
      • Begin by wedging the plastic opening tool behind the bottom left corner of the LCD screen as shown.
      • Slide the plastic opening tool to the right, along the mating edge, to pry off the back cover.
      • Continue taking off the back cover along the left side of the camera as seen in the third picture.
      Ask FixBot
    5. Canon PowerShot A2200 Back Cover Replacement: step 5, image 1 of 3 Canon PowerShot A2200 Back Cover Replacement: step 5, image 2 of 3 Canon PowerShot A2200 Back Cover Replacement: step 5, image 3 of 3
      • Use the plastic opening tool to separate the top section of the back cover from the frame.
      • Once there is enough separation between the back cover and the frame, remove the back cover for replacement.
      Ask FixBot
Author
with
Jessica Huebschman
143 Reputation
1 Guide authored
Baylor, Team 4-5, Williams Spring 2015 Member of Baylor, Team 4-5, Williams Spring 2015
BU-WILLIAMS-S15S4G5
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 18
Past 30 Days: 108
All Time: 1,917
