Canon PowerShot A1000 IS Case Disassembly
Views: 3.4K
View statistics:
Past 24 Hours:
5
Past 7 Days:
19
Past 30 Days:
113
All Time:
3,442
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Community-Contributed Guide
Introduction
Go to step 1 ↓
The Cannon PowerShot A1000 IS is a compact digital camera. This guide gives instructions to remove and reattach the plastic casing when attempting internal repairs.
Tools
    1. Canon PowerShot A1000 IS Case Disassembly, Canon PowerShot A1000 IS Case Disassembly: step 1, image 1 of 3 Canon PowerShot A1000 IS Case Disassembly, Canon PowerShot A1000 IS Case Disassembly: step 1, image 2 of 3 Canon PowerShot A1000 IS Case Disassembly, Canon PowerShot A1000 IS Case Disassembly: step 1, image 3 of 3
      • Transfer screws to a safe place upon removal.
      • The case is held together with two types of screws: fine thread screws that attach the case to the metal parts below, and coarse thread screws that attach the case to the plastic battery compartment.
      Ask FixBot
    2. Canon PowerShot A1000 IS Case Disassembly: step 2, image 1 of 2 Canon PowerShot A1000 IS Case Disassembly: step 2, image 2 of 2
      • Remove the two coarse thread screws on the side of the device, to the left of the camera lens.
      Ask FixBot
    3. Canon PowerShot A1000 IS Case Disassembly: step 3, image 1 of 2 Canon PowerShot A1000 IS Case Disassembly: step 3, image 2 of 2
      • Remove the two fine thread screws on the side of the device, to the right of the camera lens.
      Ask FixBot
    4. Canon PowerShot A1000 IS Case Disassembly: step 4, image 1 of 3 Canon PowerShot A1000 IS Case Disassembly: step 4, image 2 of 3 Canon PowerShot A1000 IS Case Disassembly: step 4, image 3 of 3
      • Remove the two coarse thread screws and the single fine thread screw from bottom the camera.
      Ask FixBot
    5. Canon PowerShot A1000 IS Case Disassembly: step 5, image 1 of 2 Canon PowerShot A1000 IS Case Disassembly: step 5, image 2 of 2
      • Remove the one coarse thread screw underneath the battery cover.
      Ask FixBot
    6. Canon PowerShot A1000 IS Case Disassembly: step 6, image 1 of 3 Canon PowerShot A1000 IS Case Disassembly: step 6, image 2 of 3 Canon PowerShot A1000 IS Case Disassembly: step 6, image 3 of 3
      • Gently pry apart the two covers starting from the bottom. When there is a 1/4" gap, run your finger gently along the the top of the camera, on the back cover, to release the three catches that secure the shell.
      Ask FixBot
    7. Canon PowerShot A1000 IS Case Disassembly: step 7, image 1 of 2 Canon PowerShot A1000 IS Case Disassembly: step 7, image 2 of 2
      • Gently remove both sides of the casing.
      Ask FixBot
    8. Canon PowerShot A1000 IS Case Disassembly: step 8, image 1 of 2 Canon PowerShot A1000 IS Case Disassembly: step 8, image 2 of 2
      • When replacing the cover, remove the AV/USB rubber cover for easier reconstruction.
      • Replace the front cover first leaving a small gap on the left hand side of the device for easy reattachment of the back cover.
      • Reattach the back cover by aligning it with the front cover and snapping the latches into place. Secure with screws in any order.
      Ask FixBot
2 other people completed this guide.
Biff Wheeler
762 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 19
Past 30 Days: 113
All Time: 3,442
