Canon Pixma MP480 Data Port Replacement
    1. Canon Pixma MP480 Data Port Replacement, Rear and Side Panel: step 1, image 1 of 2 Canon Pixma MP480 Data Port Replacement, Rear and Side Panel: step 1, image 2 of 2
      • Remove the two 7.9 mm screws using a Phillips #1 screwdriver.
      Ask FixBot
    2. Canon Pixma MP480 Data Port Replacement: step 2, image 1 of 1
      • Lift up the back cover to remove it.
      • You may need to lift firmly as it requires quite a bit of force.
      Ask FixBot
    3. Canon Pixma MP480 Data Port Replacement: step 3, image 1 of 1
      • Open the front tray.
      Ask FixBot
    4. Canon Pixma MP480 Data Port Replacement: step 4, image 1 of 2 Canon Pixma MP480 Data Port Replacement: step 4, image 2 of 2
      • Open the scanner compartment.
      • Make sure the blue lever locks into place to keep the compartment open.
      Ask FixBot
    5. Canon Pixma MP480 Data Port Replacement: step 5, image 1 of 2 Canon Pixma MP480 Data Port Replacement: step 5, image 2 of 2
      • Remove the blue lever from its slot by pushing it back and twisting clockwise.
      • Close the scanner compartment and cover.
      Ask FixBot
    6. Canon Pixma MP480 Data Port Replacement: step 6, image 1 of 2 Canon Pixma MP480 Data Port Replacement: step 6, image 2 of 2
      • Pry open the side cover with the plastic opening tool.
      Ask FixBot
    7. Canon Pixma MP480 Data Port Replacement: step 7, image 1 of 2 Canon Pixma MP480 Data Port Replacement: step 7, image 2 of 2
      • Flip the printer over so that the bottom of the printer is facing you.
      • Use the plastic opening tool to remove the corner of the side panel from the plastic pin.
      Ask FixBot
    8. Canon Pixma MP480 Data Port Replacement: step 8, image 1 of 2 Canon Pixma MP480 Data Port Replacement: step 8, image 2 of 2
      • Use the plastic opening tool to loosen the side panel from the bottom of the printer.
      Ask FixBot
    1. Canon Pixma MP480 Data Port Replacement, LCD: step 9, image 1 of 2 Canon Pixma MP480 Data Port Replacement, LCD: step 9, image 2 of 2
      • Using the plastic opening tool, pry off the top cover of the LCD assembly.
      • Pry around the front and side edges for the easiest removal.
      Ask FixBot
    2. Canon Pixma MP480 Data Port Replacement: step 10, image 1 of 1
      • After removing the top cover of the LCD assembly, remove the LCD using the plastic opening tool.
      Ask FixBot
    3. Canon Pixma MP480 Data Port Replacement: step 11, image 1 of 1
      • Gently pull the ribbon cable to remove the LCD completely.
      Ask FixBot
    1. Canon Pixma MP480 Data Port Replacement, Buttons: step 12, image 1 of 1
      • Locate the buttons on the top of the printer.
      Ask FixBot
    2. Canon Pixma MP480 Data Port Replacement: step 13, image 1 of 1
      • Using the plastic opening tool, gently pry under the button cover to remove it from its fixture.
      Ask FixBot
    3. Canon Pixma MP480 Data Port Replacement: step 14, image 1 of 2 Canon Pixma MP480 Data Port Replacement: step 14, image 2 of 2
      • Remove the five 7.7 mm screws using a Phillips #1 screwdriver.
      Ask FixBot
    4. Canon Pixma MP480 Data Port Replacement: step 15, image 1 of 2 Canon Pixma MP480 Data Port Replacement: step 15, image 2 of 2
      • Using the plastic opening tool, gently pry around the cover behind the LCD screen to remove it from its fixture.
      Ask FixBot
    5. Canon Pixma MP480 Data Port Replacement: step 16, image 1 of 2 Canon Pixma MP480 Data Port Replacement: step 16, image 2 of 2
      • Remove the two 7.8 mm screws using a Phillips #1 screwdriver.
      Ask FixBot
    6. Canon Pixma MP480 Data Port Replacement: step 17, image 1 of 1
      • Gently pull the LCD screen up to remove it from its fixture.
      Ask FixBot
    7. Canon Pixma MP480 Data Port Replacement: step 18, image 1 of 1
      • Use the plastic opening tool to pry off the plastic button assembly.
      Ask FixBot
    8. Canon Pixma MP480 Data Port Replacement: step 19, image 1 of 1
      • Gently pull the plastic button assembly up to remove it.
      • The plastic button assembly has a ribbon cable connected on the bottom, so be careful pulling it.
      Ask FixBot
    9. Canon Pixma MP480 Data Port Replacement: step 20, image 1 of 1
      • Remove the ribbon cable connected to the backside of the plastic button assembly.
      Ask FixBot
    10. Canon Pixma MP480 Data Port Replacement: step 21, image 1 of 2 Canon Pixma MP480 Data Port Replacement: step 21, image 2 of 2
      • Remove the seven 8.7 mm screws using the Phillips #1 screwdriver.
      Ask FixBot
    11. Canon Pixma MP480 Data Port Replacement: step 22, image 1 of 3 Canon Pixma MP480 Data Port Replacement: step 22, image 2 of 3 Canon Pixma MP480 Data Port Replacement: step 22, image 3 of 3
      • Locate the spring that holds the PCB in place on the bottom left of the plastic button assembly.
      • Gently lift the spring and pull the board out of its plastic button assembly.
      Ask FixBot
    12. Canon Pixma MP480 Data Port Replacement: step 23, image 1 of 1
      • Remove the buttons from the plastic button assembly.
      Ask FixBot
    1. Canon Pixma MP480 Data Port Replacement, Data Port: step 24, image 1 of 2 Canon Pixma MP480 Data Port Replacement, Data Port: step 24, image 2 of 2
      • Remove the 7.5 mm screw using the Phillips #1 screwdriver.
      Ask FixBot
    2. Canon Pixma MP480 Data Port Replacement: step 25, image 1 of 2 Canon Pixma MP480 Data Port Replacement: step 25, image 2 of 2
      • Remove the five 3.5 mm screws using the Phillips #1 screwdriver.
      Ask FixBot
    3. Canon Pixma MP480 Data Port Replacement: step 26, image 1 of 1
      • Remove the small plastic clip using the spudger.
      Ask FixBot
    4. Canon Pixma MP480 Data Port Replacement: step 27, image 1 of 1
      • Pull the plastic inserts out of the holes in the top and bottom.
      Ask FixBot
    5. Canon Pixma MP480 Data Port Replacement: step 28, image 1 of 1
      • Remove the board from the printer by pulling the board towards the back of the printer.
      • This requires effort and time as the board comes out slowly.
      Ask FixBot
Steven MacLean
86 Reputation
2 Guides authored
Cal Poly, Team 19-41, Regan Winter 2013 Member of Cal Poly, Team 19-41, Regan Winter 2013
CPSU-REGAN-W13S19G41
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 8
Past 7 Days: 26
Past 30 Days: 111
All Time: 2,891
